I've fitted a lubetronic oiler with the controller to my 2009 Tiger.
With a Scott Oiler dual feed located under the Swing arm.
I was able to fit the unit directly to the frame under the nearside seat cowl.
I've extended the filler pipe which is now accessable from the rear
Does anyone know of a suitable conveinient feed under the seat?
This needs to be ignition fed so only on when the ignition is on,
saving oil and battery, the unit itself has an inline fuse and minimal
current draw. I don't want to use a switch as I think I would forget to turn it on /off and that defeats the object of fitting the oiler to save wear and extend the chain life.
Any Ideas or previous experience with this type of setup please!
