I think the installation of a plastic fuel filter on a fuel injected bike is a very misguided step. Those plastic inline filters were designed for use in carbureted systems of years ago that operated at less than 12 psi pump pressure. Just about any motorcycle of car FI system is operating in the 35-50 psi range. The plastic filter submerged in fuels is likely to give in short order. Also be aware that there is a different spec for fuel line in FI systems to withstand the higher pressure and being submerged in fuel. Using regular fuel hose is a no no here too.
As i own both a 955 Tiger and a BMW 1100s i can assure you they use the same fuel filter,just comes a lot cheaper at the BM dealer!!,knowing what BM can be like even i find it strange.
