Balancing throttle bodies ? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 13 (permalink) Old 06-10-2008, 06:47 PM
Originally Posted by tiger LT View Post
Hi there, I just bought a 99 tiger and as im changing spark plugs and filters, i thought its a good idea to balance the carbs too. Is the method you described gona work on 99 tiger, coz I think mine fuel injected version. m?
cheers,
Algis
I say anytime you have the tank off, go for it, I sure will be. Once the tank is off it takes a matter of five minutes to do the sync. The 99 should be the same deal, according to my Haynes manual.
As for me, the bike was running just fine aside from vibes at speed, but I do notice that it idles much more smoothly after adjustment.
jetpoweredmonk is offline
post #12 of 13 (permalink) Old 06-20-2008, 09:58 AM
Main Motorcycle: 2006 Tiger
Extra Motorcycle: 1978 Yammer RD 250
Did my 24k service last weekend including throttle body sync. Idle is much improved as is throttle response. Since I did not have the Triumph digital vac tool or a mercury column, I used a UniSyn tool from my old VW Weber carb days. The UniSyn is placed over each throttle body opening individually (cap off the vac ports used with merc column ) and a floating pill measures base idle air flow by rising in a small glass tube. Get the pill to rise the same for each throttle and your there. Worked for me.
p2gee is offline
post #13 of 13 (permalink) Old 09-13-2015, 09:24 PM
Main Motorcycle: 1999 Sprint ST
Other Motorcycle: 1985 Honda Nighthawk 700S
Extra Motorcycle: 88 Ninja 750R cafe racer
Any suggestions on how to hook up the fuel tank and where to position it on a 99 sprint with FI. Do I need to hook up the red fuel return connector?
DeusExMaxima is offline
How to sync throttle bodies? fryingtonite Speed Triple Forum 17 03-17-2009 09:09 PM
Balancing injectors/ throttle bodies on a 01 Triumph Sprint ST Tequila1 Maintenance & Workshop Talk 16 02-04-2009 09:02 AM
Balanced my throttle bodies CLB Sprint Forum 27 03-28-2008 11:16 AM
Leaking throttle bodies BJ Sprint Forum 2 09-30-2006 04:38 PM
Has anyone synchronized the throttle bodies on their own? CharlestonRider Sprint Forum 2 07-11-2006 12:42 PM
