Replacing pads... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-11-2006, 04:13 PM   #1 (permalink)
I'm about to replace the rear and front pads on my '05, per the '01 shop manual - any prior advice would be welcomed.
Thanks,
Walt
OAK
TiggerTwo is offline
Old 07-12-2006, 07:11 AM   #2 (permalink)
robbie's Avatar
Get a very good flat screwdriver that fits or you will***** up the allen screw cover.
clean everything before you start
a G clamp is useful for pushing the pistons back
copperslip all the bearing surfaces except the rubber boot
don't forget to take some fluid out if you have toped up during the life of the pads.
good luck
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
robbie is offline
Old 07-12-2006, 10:33 AM   #3 (permalink)
good luck
Thanks -
F.Y.I.
Found a distributor of "Coppaslip", here, in the U.S.
They will be sending a tube of this stuff to me as a sample. However, they said any "anti-seize", high-temp, key: "high-temp", grease is acceptable for this sort of application.
[ This message was edited by: TiggerTwo on 2006-07-12 09:18 ]
OAK
Old 07-12-2006, 11:13 AM   #4 (permalink)
Favourite Bike: None at the moment
Other Motorcycle: '09 KLR/'09 TU 250X
On 2006-07-12 08:33, TiggerTwo wrote:
Thanks -
F.Y.I.
They will be sending a tube of this stuff to me as a sample. However, They said any "anti-seize", high-temp, key "high-temp" grease is acceptable for this sort of application.
That is true, any good anti-seize is fine. The rest of Robbie's suggestions are spot on as usual. I find it useful to regularly take off the caliper pins so that they don't seize but I ride the bike in the winter in Maine...
Fred
No such thing as cold weather, just inappropriate clothing.
pigpen955 is offline
Old 07-13-2006, 07:51 AM   #5 (permalink)
robbie's Avatar
Fred
A lot of High temp anti-seize greases are based on Molybdenum disulfide. we have here Moly-slip
Moly turns abrasive if contaminated by water
Moly is OK for inside an engine but not for things such as calipers and chains
TIGER 955i 2003
robbie is offline
Old 07-13-2006, 08:47 AM   #6 (permalink)
Hi Fred and Robbie,
Thanks for the advice. A tube is on it's way. In the mean time I'd really like to find one without the Molybdenum disulfide base - any suggestions?
Also, the shop manual describes the front pad replacement procedure without removing the calipers (page 13.9). Then it goes on to say that the rear pad procedure is the same as the front and one must refer to the front procedure (page 13.17).
Almost as if they are saying to use the disc to retain the pistons as the pad is withdrawn.
Would be interesting to hear an opinion on this. Perhaps I'm mis-interpreting the procedure.
[ This message was edited by: TiggerTwo on 2006-07-13 06:50 ]
OAK
Old 07-13-2006, 09:28 AM   #7 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
You can do it like that but I prefer to whip the caliper off and have a good look at the pistons, clean them up etc. It's only a couple of bolts to remove.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is online now
Old 07-13-2006, 02:09 PM   #8 (permalink)
So, you pop out the pistons and wipe 'em down?
Sound's like good advice.
Thanks ~
OAK
Old 07-13-2006, 04:12 PM   #9 (permalink)
Fred
Ribbie-
Thanks, I didn't know that. I quess that is my one thing for today
Fred
Old 07-13-2006, 07:45 PM   #10 (permalink)
KuzzinKenny's Avatar
NO !! Warning !! Warning !! missread !! missread !! :???:
i think what iansoady meant was to clean the part of the pistons that you can see, without removing them. when you have the caliper out it gives you a chance to check the piston for marks, scores and freedom of movement and also check the dust seal for splits. try NOT to pop the pistons out unless you are overhauling them.
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Replacing Tires - Both at once regardless? Tenover Twins Technical Talk 12 12-03-2007 12:04 AM
TT600 replacing my S4 dkurtz Triumph SuperSports 9 12-07-2006 03:11 PM
Replacing my 03 st zore Speed Triple Forum 5 08-28-2006 12:33 PM
Replacing the Sprint_Rdr Sprint Forum 8 01-23-2005 02:23 PM
Replacing the Sprint? T3 Sport / Touring Forum 8 07-09-2004 07:13 PM
