First things first!! there no such thing as front end sag!!
The rear is 15/20mm but it ain't life and death suspension is alike a golf swing there's a classic set up but there are plenty of others that work just as well!!.
The way you checked your sag is novel!!,stand behind your bike holding the rack,press down on the rack compress the suspension,let it come back up,measure from the floor to a spot on the rear subframe,when you have that measurement,put your hands underneath the rack and lift up,measure again,the difference is the sag!!!.
As for the front,the forks are pretty poor,so your never going to make a silk purse of a sows ears!! so to speak,put some progressive springs in of any make you like and tinker with the oil grades and quantities,there are guys who have put gold valves in,just a case of how serious you are.
[ This message was edited by: winger on 2006-07-09 12:33 ]
