scottoiler - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
SportbikeTrackGearHonda PowersportsMotorcycle.com Classifieds!Motorcycle.comOntario Tourism
Old 07-05-2006, 02:36 PM   #1 (permalink)
Skidpan's Avatar
I have just got an 03 Tiger that already has fitted to it, a scottoiler. The reservoir is attached to the frame tube at the bottom of the left hand side panel, and is awkward to refill. Where do you have your reservoir fitted, and how easy is it to get at?
The Oboto Sobatmas - The Finest, Most Exclusive Gathering of Gentlemen Motorcyclists. Sponsored by Deuchars, Fuelled by Stupidity...
The Obo Scribe mutters at http://obotosobatmas.blogspot.com/
Skidpan is offline
Old 07-05-2006, 07:07 PM   #2 (permalink)
Favourite Bike: Tiger 1050
Other Motorcycle: Fazer 600
Hi Skidpan
I've got mine in the same place, and yes, it's a pain to fill and readjust, but well worth it apart from that - I wouldn't want to be without it. I've been looking at buying the touring reservoir you put behind the numberplate, this is an upgrade option for the smaller Scottoilers. Only slight problem is moving the number plate light back to still illuminate your rear plate, but reckon it will be well worth it to not have to take panels off every 4-500 miles...
TorqueyT
TorqueyT is offline
Old 07-06-2006, 07:47 AM   #3 (permalink)
Favourite Bike: 955i Tiger
Other Motorcycle: ex. Kwak Zephyr 750
Extra Motorcycle: 1050 Speed Triple, I wish
I haven't fitted mine yet but thats where i intend to put mine. I have also got the Scottoiler Lube Tube which should fit under the seat and give extra distance between fills and will be much more accessable
- The more I ride 'er, the more I luv 'er -
jimbo2807 is offline
Old 07-07-2006, 03:58 PM   #4 (permalink)
I've made a stainless steel bracket which locates to two screws on the final drive sprocket cover. Easy to fill and adjust flow rate.
daveyl is offline
Old 07-08-2006, 05:13 AM   #5 (permalink)
Skidpan's Avatar
That sounds like a good idea, do you have any pix?
Skidpan is offline
Scottoiler TripleTreat Sprint Forum 2 11-10-2006 03:32 AM
Scottoiler..... casperghst42 Sprint Forum 2 05-23-2006 10:30 AM
Scottoiler llewpants Tiger Mods & Bolt-Ons (archive) 21 02-22-2006 03:01 AM
Scottoiler for 05 ST STman Sprint Forum 8 07-28-2005 04:57 PM
Scottoiler on 05 S3 wyrdness Speed Triple Forum 2 05-10-2005 03:29 PM
