Dim Headlights - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-19-2006, 04:32 PM   #1 (permalink)
My headlights on dim have lost there brightness. When
I put the brights on the bright left front shines ok but on the
right light it is very dim. Could this be a battery thing, I have had trouble with this same battery before. It's cranking fine, so I would think it would rule out the battery. If it was a fuse it would fail completely, I would think.
I am going to trickle charge the battery up to a full charge to see if that helps.
Am I missing something.
Tks,
Dirtdog (usa B'ham, al)
Dirtdog1
Dirtdog1 is offline
Old 06-19-2006, 05:05 PM   #2 (permalink)
Blown headlight bulb? Could be just the sidelight lit on the right hand side.
Foxee is offline
Old 06-21-2006, 05:33 AM   #3 (permalink)
Favourite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
If your bulbs are intact, I'd look for a ground fault. Sounds like one of the ground lugs isn't... grounding, that is.
tyrebyter is offline
A safety tip for dim wits...like me. Ridge Twins Talk 8 05-07-2007 11:03 AM
This tail light is really dim daveedsfast Triumph SuperSports 5 04-26-2007 10:57 PM
new headlights FuryFour Triumph SuperSports 32 04-22-2007 05:37 PM
S4 Headlights Stampy Triumph SuperSports 3 06-20-2006 01:33 PM
Foot brake light doesn't dim Triumph SuperSports 13 10-22-2004 08:14 AM
