Towing question [front end & gaiters].... - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 06-18-2006, 12:14 AM   #1 (permalink)
BULLman's Avatar
I know, I know. Towing your Tiger Suks, but I gotta get to the good roads quick!
I have a bike pro chock, that basically holds the bike up - but am not sure where to tie down the front end.
I usually put soft wraps around the forks - but with the gaiters there, I decided to use my crash guards instead.
I don't want to screw up the gaiters, but don't want the bike to flip out [again ]
Please share your thoughts. Thanks.
BULLman
'04 Kawasaki Concour aka OLDskool
Moderator of Fla_RATs
BULLman is offline
Old 06-18-2006, 12:47 PM   #2 (permalink)
KuzzinKenny's Avatar
check this out clicky Here
hope this works !!
KK
ps and Click
[ This message was edited by: KuzzinKenny on 2006-06-18 10:53 ]
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Old 06-19-2006, 09:59 PM   #3 (permalink)
BULLman's Avatar
hope this works !!
KK
ps and Click
Good links, Good info...
but, nothing on Gaiters :hammer:
BULLman
BULLman is offline
Old 06-20-2006, 04:15 AM   #4 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
I'm not sure what the problem is - are you worried that compressing the forks will permanently distort the gaiters (unlikely) or are you considering attaching tie-downs to the fork where the gaiter fits (inadvisable IMO).
When I used to use a trailer regularly for my trials Enfield I attached the straps to the handlebars. I think you could do the same with the Tiger, but you may need some soft padding.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 06-20-2006, 04:43 AM   #5 (permalink)
I've never used the fork legs to secure a bike on a trailer myself, I've tended to use the handlebars as the front anchor points (as Ian mentions); but I'm not sure of the configuration of your trailer so it may be the only option?
If so, you can easily loosen the screw on the jubilee clip which secures the bottom of the gaiter to the fork stanchion, and slide it up a couple of inches.
I don't think it sounds like the best option if there's any other way to secure the bike at all; depending on the way you tied it down it could put undue stress on the fork components in a way they weren't designed for :???:
tcowjww is offline
Old 06-20-2006, 08:28 AM   #6 (permalink)
Try these - Tie downs
I have something similar, needed to get both my car & bike to Brittany a couple of years ago, worked a treat.
Good luck
Keep it sunny side up
Sharkee is offline
Front end JKDJose Twins Technical Talk 16 01-21-2008 11:11 AM
Gotta get gaiters! Install question(s) boboso Club Cafe' 7 11-13-2007 06:28 PM
Shaking front end when applying front brakes. stealthy1 Daytona Deliberations 10 11-23-2006 05:34 PM
Gaiters Installed...but question bosoxrider Twins Talk 3 09-05-2005 08:14 PM
Front end whine; Ken Sean Mirrors; best cover question S3xtatic Speed Triple Forum 2 05-18-2005 04:11 PM
