Keys - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearHonda PowersportsNew Bonneville
Old 06-14-2006, 11:11 PM   #1 (permalink)
JRO
Favourite Bike: 06 Tiger
JRO's Avatar
Other Motorcycle: 07 FJR 1300
Extra Motorcycle: 07 R3 Tourer
Anyone have their Tiger changed to singlekey?
I'm going to have to make some change. My key was taken out of the ignition yesterday, by a passerby. I can't leave it parked in the yard during the day, anymore. Have to lock the garage at night now, too.
Anyway, I'm going to have to re-key the ignition, or just replace it with another one, and while I was at it, I thought I might see about having the luggage all re-keyed to match the ignition. Anyone have this done?
JRO is offline
Old 06-15-2006, 12:31 AM   #2 (permalink)
I got a quote for $15 per lock.
Walt
OAK
TiggerTwo is offline
Old 06-15-2006, 03:24 PM   #3 (permalink)
Expect to have a bit challenge getting the ignition lock off.
Triumph use shear bolts, hence there is nothing to grip the remaining stub with. They are also recessed in.
You may be lucky with mole grips or small wrench but its likely you will have to remove a lot of the front end just to get access. You may then end up chiseling them out.
The only reason I know is because mine fell out!!!
I replaced them with socket heads.
Regards
Chris
Arrybash is offline
Old 06-16-2006, 04:25 AM   #4 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
So does everyone else (both bikes and cars) and I've never understood why, as a thief will just smash the thing rather than try to undo bolts.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 06-16-2006, 01:36 PM   #5 (permalink)
Favourite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
Just smashing a lock cylinder is not as effective as it once was. There are a number and variety of electrical interlocks on most modern designs that require a bit more creativity. I've used a needle-nose Vice-Grip with some success for getting the blind feasteners out but never tried the Tiger. Others have tac-welded a rod to the fastener head.
Noticed that my ignition/fuel/seat lock is a different key blank than the bags. Is that because of different model years?
tyrebyter is offline
Old 06-16-2006, 01:40 PM   #6 (permalink)
iansoady's Avatar
No I think they're all like that. The luggage key seems to have fewer indentations therefore probably easier to pick.
Ian
2004 Tiger 955i
iansoady is offline
Old 06-16-2006, 11:18 PM   #7 (permalink)
Favourite Bike: Tiger
Other Motorcycle: 89 Moto Guzzi Mille
Extra Motorcycle: 67 BSA 441
I expect I got jammed but I had an ignition key copy made and the blank was $26. Sometime about being a special import that very few vehicles use. And he didn't have the luggage blank which saved me a bundle.
Sometimes it takes a whole tank before one can think straight
Anthouse is offline
Old 06-30-2006, 11:53 AM   #8 (permalink)
madmic's Avatar
sorry to hear about the theft of your key, I once dropped mine in Vancouver, and thought I was screwed, but the guy turned it in to a bar nearby...lucky.
As for the tiger having two keys..I too believe they are all like that. At least mine is, and its an 03. I have found that most places cant do a copy cause the keys are kind of unique, thus you probably have to buy the blank first from the dealer. I did lose my keys once to another bike and a locksmith was able to make new ones...but it was not stolen, and you have to worry about the thief returning for your bike....that sucks. -Mike
Dare mighty deeds, win glorious victories even if checkered by defeat.
madmic is offline
Old 07-06-2006, 03:11 AM   #9 (permalink)
JRO
JRO's Avatar
I am currently convinced the 'thief' is probably under 10 years old, and it was likely deposited in a neighborhood yard or alley. There is also the possibilty that it is in the bottom of a toy box. So, maybe somebody's mother will turn it up, take a look at it, and remember that I have the only Triumph around.
Haven't found a locksmith with any blanks, so I guess I'll have to pick one up when I get near a city with a dealer.
JRO is offline
Keys geolpilot Twins Technical Talk 7 10-17-2007 03:48 PM
Keys just_phil Hinckley Classic Triples 4 06-27-2007 06:38 PM
Keys Paul-K Sprint Forum 9 05-03-2007 08:34 PM
All these keys... dmsum Tiger Chat 8 03-14-2007 06:46 PM
Replacement Keys RalphS Sprint Forum 5 05-09-2004 03:33 PM
