Alarm Socket - Where is it? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-10-2006, 05:25 PM   #1 (permalink)
AlexC
I have recently bought a Tiger 955i (05) and would like to fit an alarm. According to the wiring diagram there is a socket in the wiring harness. So far so good.
Question is where is it hiding? Have done a quick look see under the seat and side panels - no joy.
Would anyone happen to know before I start pulling off the cockpit and tank?
Thanks
Alex
Old 06-11-2006, 02:48 AM   #2 (permalink)
Alex.
All you need to do is remove the rear seat cowl and you will see the connector plug just below the seat locking mechanism. It has two loops of wire on it, pull this plug out and plug in the alarm. If you need any further help just ask here.
TF.
Tigerfeet is offline
Old 06-22-2006, 01:23 PM   #3 (permalink)
blacktiger's Avatar
Additionally, I'd recommend that you keep that plug taped under the rear cowl just in case the alarm plays up. Then you can disconnect the alarm and get home OK.
I had to do just that in Spain last year when the alarm decided to drain my battery over night.
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
'12 Tiger800XC in black. 11500 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
blacktiger is offline
Power Socket Jhtjon Twins Technical Talk 7 10-15-2007 01:09 AM
socket type triumphtimes Daytona Deliberations 2 05-11-2007 06:26 PM
elec socket millwallfcuk Trophy 3 05-04-2007 01:38 PM
Accessory socket jackn Tiger Chat 29 12-26-2005 10:53 PM
SCART Socket! kweller Tiger Chat 3 08-15-2005 04:02 AM
