955i fuel octane requirement... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-08-2006, 08:17 AM   #1 (permalink)
The '05, Owner's Handbook, call's for 95 RON.
What RON or MON do you use in your 955i Tiger? Does your 955i "ping" or not?
Here's a RON/MON/PON, fuel rating reference:
www.btinternet.com/~madmole/Reference/RONMONPON.html
Here's another one:
Definition of octane ratings
Walt
[ This message was edited by: TiggerTwo on 2006-06-08 07:04 ]
OAK
TiggerTwo is offline
Old 06-08-2006, 08:53 AM   #2 (permalink)
Favourite Bike: 01 Tiger
Other Motorcycle: 02 Sprint RS
Extra Motorcycle: another 01 Tiger
95 RON is about equivalent to 89 on our standard. I haven't had any pinging running the 89 ethanol we have around here. I have a Friend who uses 87 without the ethanol and swears by it and guarantees I'll get better gas mileage. I'll stick to the 89 ethanol.
nortoncharlie is offline
Old 06-08-2006, 07:07 PM   #3 (permalink)
JRO
Favourite Bike: 06 Tiger
JRO's Avatar
Other Motorcycle: 07 FJR 1300
Extra Motorcycle: 07 R3 Tourer
I usually fill up with 89oct., but sometimes go with 87. Haven't noticed any pinging with either.
Considering trying some drip gas, also. I'll let you know what happens.
JRO is offline
Old 06-08-2006, 10:04 PM   #4 (permalink)
Drip Gas and other Mysteries of Oklahoma
OAK
Old 06-09-2006, 07:49 AM   #5 (permalink)
Favourite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
No pinging on any flamable liquid I've found but I use Chevron Premium when available for the detergents.
tyrebyter is offline
Old 06-09-2006, 12:50 PM   #6 (permalink)
The knock sensor will alter the ignition to suit, thats why you don't get any pinging. Still doesn't mean you should be using low octane fuel.
nobby400 is offline
Old 06-09-2006, 08:35 PM   #7 (permalink)
JRO
JRO's Avatar
My appologies; I didn't realize most folks don't know what drip gas is.
Drip gas is a 'natural' form of gasoline, to save chemical explanations. It's clear, collects from the surface of oil pools, condenses out of natural gas, and is common in our local oil/gas bearing strata. I don't think it is exclusively unique to Oklahoma-NorthTexas, but it's unusual, elsewhere.
There are 'condensers' on local natural gas pipelines, where the stuff is collected out. You can find something similar on many production oil wells. Production companies hate the stuff; it's 'waste', as there isn't enough for viable comercial collection/refining, and there is no uniformity to it. They have to periodically collect it and dispose of it. The octane might be anything up to 80. You can obtain it from a condenser or collection tank, and use it to run a lawnmower with - or anything else, depending on quality.
It's illegal to use, because the State gets really pissed whenever somebody fuels something, and they can't get their tax fingers into it. During WW2 there was gas rationing, and anyone caught using 'drip' would get into real trouble. Today, there's little enforcement, although you can still get into trouble (if anybody bothered to catch you). Oil/gas companies sometimes complain when it disappears from collection points, because they don't like anybody using something they're going to throw away.
We used to burn a lot of drip in an old Internation Scout. We had a good source, and ran a lot of small engines with the stuff, also. You have to set your timing back for most vehicles, but high-octane drip will run a car. I've heard of drip that was too 'hot' (too much octane), but have never seen any, and don't believe the reports. Lots of drip is low-octane and will smoke, or a motor just won't start on it. Even the poor stuff can still be used, however, by mixing it with something to improve octane (store-bought gasoline, for instance).
Drip can be handy, when you run out of gas in the middle of nowhere at two in the morning, but you happen to find a source nearby. Use of it carries a stigmata of 'cheap' or 'devil-may-care', depending on attitude.
Good 'nuff?
JRO is offline
Old 06-11-2006, 06:24 PM   #8 (permalink)
Favourite Bike: 2002 Tiger
pineygroveshop's Avatar
87.
Cheers,
Stephen Ford
pineygroveshop is offline
Old 06-14-2006, 05:51 PM   #9 (permalink)
Diego's Avatar
There is no such thing on the Tiger.
John
Diego is offline
Old 06-16-2006, 03:49 PM   #10 (permalink)
Well you learn something everyday.
nobby400 is offline
Would a higher octane fuel make a lick of difference? Reppyboyo Triumph SuperSports 15 04-09-2007 02:48 PM
Fuel/Octane/Additives/Jet Fuel Rumors Xavi Triumph SuperSports 20 02-25-2007 05:50 PM
What Octane Fuel should I use on my 2003 Sprint ST? steevg Sprint Forum 13 12-28-2006 07:04 PM
Spark plugs for high octane fuel ?? Binnsy Twins Technical Talk 11 08-21-2006 09:19 PM
Gas Mileage Improved w/Flyscreen & 89 Octane Fuel Liontari Twins Talk 8 05-27-2006 07:02 AM
