Spongy Brakes - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-04-2006, 01:08 AM   #1 (permalink)
Has anyone else noticed how fast the brakes go off on these here Tigers. One minute every things fine.The next the levers almost touching the handlebars. :???: :???:
pastitoo is offline
Old 06-04-2006, 11:01 AM   #2 (permalink)
ipg
Just what I was thinking the other day when I was out, so I've just finished bleeding them today and you know what, I think they are still the same????
Must be spending too much time on my BM where the brakes are servo assisted and you only need one finger to pull to a fast stop. Back on the Tiger and it's a full handful and pulled close to the grip.
I'm going to cable tie the brake lever squeezed back over night and see if I can get anymore air out of the system, but I'm not hopeful.
IPG
Keep it rubber side down!
MyPhoto Album
ipg is offline
Old 06-04-2006, 01:43 PM   #3 (permalink)
Always let the brake fluid stand for a few days never put it straight from the shops. Stops any air being in the fluid.
nobby400 is offline
Old 06-05-2006, 12:48 PM   #4 (permalink)
KuzzinKenny's Avatar
Never leave the top off a brake fluid container, brake fluid absorbes moisture from the air and if you put that in your system the water will evaporate when hot and give you spongy brakes again !!
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Old 06-05-2006, 03:26 PM   #5 (permalink)
nehpetsthegrey's Avatar
Its a common problem with triumph's. If you search the data date you will find many cures and suggestions. My way is to to open the master cyclinder cap and apply the brakes. Then fix the cap back. It seems to be a vacuum thing.
nehpetsthegrey.
as grey as gandalf but not quite as old
nehpetsthegrey is offline
Spongy brakes Steve675 Speed Triple Forum 14 05-10-2006 03:21 PM
Spongy brakes Steve675 Sprint Forum 6 04-29-2006 06:56 PM
Spongy front brakes. NROWLEY Sprint Forum 3 11-29-2004 05:12 PM
Spongy brakes Speed Triple Forum 0 11-13-2004 05:29 PM
Spongy Brakes? Try this first... SpiderTex Sprint Forum 6 09-18-2004 11:00 PM
