Rear spring adjustment - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda PowersportsMotorcycle.comMotorcycle.com Classifieds!
Old 05-30-2006, 04:11 PM   #1 (permalink)
ww
Favourite Bike: Tiger 955i
Extra Motorcycle: Sprint ST 1050
Hi
I -once again - need your advice
My Tiger has developed a nasty habbit ; it started to 'wobbe' (don't know a better word for it).
Whenever I reach a speed of above 80 km/h it seems the rear wheel develops a 'wobble'.
I think have to adjust the spring. I weigh ca. 96 Kg. What would be the right setting?
Thanks
Regards
Wim from NL
ww is offline
Old 05-30-2006, 05:19 PM   #2 (permalink)
Put on a Happy face.
Set it on number 5, and turn the ajuster at the bottom of the shock to increase the compression and rebound(for what it's worth!!)it won't be enough but it's the best you can do with a stock shock.
winger is offline
Old 05-31-2006, 05:58 AM   #3 (permalink)
ww
Thank you for the advice; I'll do that
Regards
Wim from NL
ww is offline
Old 06-01-2006, 04:22 PM   #4 (permalink)
ww
Just a quick update; works better still not great but wobble is acceptable
Thanks for the help
Regards
Wim from NL
ww is offline
Old 06-02-2006, 07:32 AM   #5 (permalink)
check your rear wheel alignment and bearings then.
Have you adjusted the chain recently ? Maybe you haven't adjusted it the same both sides ?
Or your rear shock's stuffed and you need a new one. Any sign of leakage from the bottom ?
FifeTiger is offline
Old 06-02-2006, 02:07 PM   #6 (permalink)
clive955's Avatar
WW whats the milage on your Tiger, as this may help in checking if any thing is past its sell by date, and also has this fault suddenly developed or over a period of time. ??
Green is Mean
clive955 is offline
Old 06-02-2006, 03:56 PM   #7 (permalink)
YellowFellow
Last time I had a wobble it turned out to be simply low tyre pressure - which was ofcourse the last thing I checked......
Old 06-03-2006, 06:58 AM   #8 (permalink)
ww
5Tiger thnx
All good tips; here are my answers
- No problem with alignment and bearings
- chain has been adjusted but it's on 1 side only ; 2002 model with excentre and the adjustment has been checked by mechanic
- no leakage from bottom
I'll keep looking
Regards
Wim from NL
ww is offline
Old 06-03-2006, 07:00 AM   #9 (permalink)
ww
Hi Clive I'm at 13000 km
It has developed over a period of time or could be that my butt is getting sensitive by the years. :jest:
On a serious note; when I drive with my lady there is no wobble!
Regards
Wim from NL
ww is offline
Old 06-03-2006, 07:01 AM   #10 (permalink)
ww
YellowFellow I check my pressure every other day and when needed adjust. But thanks for the thought :-D
[ This message was edited by: ww on 2006-06-03 05:02 ]
Regards
Wim from NL
ww is offline
Rear Spring Setup RS.Fez Speed Triple Forum 4 08-30-2007 12:57 AM
03 ST rear spring adjustment OUTLAWD Sprint Forum 0 05-07-2007 06:57 PM
rear spring rate klingklang Tiger Mods & Bolt-Ons (archive) 0 04-30-2007 10:32 PM
Rear spring recommendations Andrew1965 Sprint Forum 4 03-02-2006 10:37 AM
spring preload adjustment oldyeller Maintenance & Workshop Talk 8 02-06-2005 02:18 AM
