Not Keen on Oil Capacity Rating, Dipstick O-Ring - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-29-2006, 01:36 PM   #1 (permalink)
Just changed the oil (Mobil 4T) on my '05 Tiger, since it didn't get done prior to winter storage last November. As there was only ~3400 miles on the synthetic, I rode it a little bit this spring (which is not my normal SOP).
The owner's manual says total oil capacity is 4.2 US gallons, or thereabouts. I had a little left in my previous 1-gallon container of Mobil 4T, so I added that first. Then I added approximately 85% of the new container before checking oil level. Bike was on centerstand (with 2X block of wood under front tire to keep it reasonably level front to back-while draining, then re-filling). Before filling crankcase, I added oil to the spin-on filter, as per the manual. Then, filled crankcase as described above. Then started engine to circulate oil throughout, and ran a couple minutes. I checked the oil level, and it was waaaay over top hash mark on dipstick. I ended up removing drain plug briefly to drop some oil, then quickly re-tightening. I repeated this process, 3-4 times, each time checking dipstick level before I was satisfied that oil volume was correct. Of course, bike was upright while checking stick. I believe the owner's manual oil capacity listed is higher than actual. Anyone else notice this? I also think that the O-ring on the dipstick should have been retained in a machined groove at the top so it doesn't fall off the dipstick almost each time it is pulled out of crankcase. It invites foreign objects into the case, and is subject to loss if not noticed-which then results in likely oil leak when riding.
It almost makes me long for my (recently sold) '97 TBird's hard to read sight glass
Gerry
TBirdG is offline
Old 05-29-2006, 03:35 PM   #2 (permalink)
Helll 4.2 Gallons thats a lot of oil :-D I thought the capacity was 4 Ltrs or about 0.9 US gallons
Dont forget that you must screw the dip stick in to check the oil level
nobby400 is offline
Old 05-30-2006, 01:27 AM   #3 (permalink)
djr
4.2 gallons!! quarts maybe but also remember that when you add to the filter then you must subtract that from the total!!
David
My Photo Album
My Tiger pages
djr is offline
Old 05-31-2006, 06:18 AM   #4 (permalink)
Favourite Bike: Black Tiger 1050
Tell me this...
I know why an engine can't run without oil but what happens when run with too much?
Lil
You’d lean on the wind when the wind came by,
You’d say to the wind when it took you away:
‘Thats where I wanted to go today!’
TigerLilly is offline
Old 05-31-2006, 09:32 PM   #5 (permalink)
Yeah, brain lock.....you guys are correct, 4.2 quarts is what I meant to write. And yes, I thread the dipstick in tightly.
Gerry
TBirdG is offline
Old 06-30-2006, 12:05 PM   #6 (permalink)
Favourite Bike: Tiger
madmic's Avatar
Ha-ha...ya had me scared for a minute...4.2 galllons! So is it 4.2 liters or quarts? Please advise....-Mike :???:
Dare mighty deeds, win glorious victories even if checkered by defeat.
madmic is offline
Old 06-30-2006, 12:59 PM   #7 (permalink)
Diego's Avatar
In actual fact, it's 4.3 liters, dry fill at the factory or after a teardown.
The shop manual says 3.9L for oil change only, or 4.0 for oil and filter change--meaning, they don't expect you to be able to get that last 0.3 liter out of the sump in a regular oil change.
John
Diego is offline
Old 07-01-2006, 07:26 AM   #8 (permalink)
blacktiger's Avatar
Dead right. And 1 litre = 1.76 pints so :-
4 x 1.76 = 7.04 pints which I would round down(ish) to :-
3.5 Quarts (UK) But, hang on a minute.....aren't US quarts different to UK quarts because of your gallon being smaller than our?? Oh, for gods sake...........
Our pints are 20 fl oz. Yours are 16 fl oz.
So, 7.04 x 20 = 140.08 fl oz divide by 16 = 8.80 US pints. So...........the answer is........
4.40 US quarts.
Seems that a US quart is very similar in size to a litre.
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
'12 Tiger800XC in black. 11500 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
blacktiger is offline
Oil filter, oil, and dipstick questions from a new owner kc5deb Sprint Forum 18 07-26-2008 11:58 PM
Oil Dipstick? fundyrider Trophy 3 09-29-2007 04:04 PM
Oil Check- Dipstick thread to bottom, or dab? Bravo Speed Triple Forum 3 12-25-2006 01:27 AM
05 oil level / dipstick. DarkSkies Speed Triple Forum 3 08-05-2005 06:20 PM
Oil leak coming from Dipstick Knightshade Speed Triple Forum 5 06-23-2004 05:35 AM
