pigpen955
A quick answer here cos got to dash, please excuse the brevity.
Three most likely causes, in no particular order of likely-hood.
1. Pressure cap failure. (radiator cap)
2. Airlock in the engine. (bleed system to cure)
3. knackered water pump.
No 2 is easiest to solve. There is a thread here somewhere on how to, or dig into Mr Haynes book of bodges.
No 1 is relatively cheap (if you can get a cap some folk have not had a lot of luck finding one) easy repair if you have small hands and good manual dexterity. Either that or you need to lift the fuel tank to get access. Can also require to bleed system if you have lost enough coolant.
No 3 needs new Water Pump I'm sure there will be someone along soon who can say what that involves.
Fingers crossed its a simple sort.
D
Big D
If you can't be kind, at least have the decency to be vague.
