Swing arm spring clips - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comNew BonnevilleSportbikeTrackGear
Old 05-19-2006, 07:28 AM   #1 (permalink)
Those springy little clips that go round the swing arm adjusters bolts (I think).
Manual says to replace them every time the chains adjusted but where do you buy them from ?
As you can see I don't even know what they're called, size, tensile strength, etc etc
FifeTiger is offline
Old 05-19-2006, 09:38 AM   #2 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
I assume you mean the circlips that go over the ends of the spindle. You don't have to touch them to adjust the chain as you don't loosen the spindle. You just have to slacken off the bolts clamping the eccentrics then rotate the eccentrics using 12mm allen keys to the desired position. Make sure you do it on the centre stand, and most people here err on the side of slackness in the chain.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Swing Arm .... NewMetal Twins Technical Talk 4 05-09-2007 05:24 AM
Tiger Swing ARM gsp0702 Tiger Chat 2 10-07-2006 04:16 AM
Removing swing-arm Bazzer Twins Talk 6 10-23-2005 07:32 PM
Swing Arm & other bits bigD Tiger Mods & Bolt-Ons (archive) 5 04-26-2005 01:20 PM
Swing arm Convertion. Maintenance & Workshop Talk 3 03-25-2005 10:25 AM
