955i rear wheel bolt jammed HELP - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-18-2006, 08:18 AM   #1 (permalink)
Fizzy
Hi
1st time posting so be gentle with me !!!!
I have bought a new rear tyre (Metz Tourace again) for my Tiger 955i spoked wheel model and went to take out the rear wheel only to find that the right 19mm bolt was seized solid and every time I tried to turn it all it was doing is spinning the inside of the wheel .... I put the left 19mm bolt back on again and tightened it but again when I tried to loosen the right bolt it just keeps spinning.
How do I stop this from happening ??? If I try to use a spanner on the left one to hold it in place while loosening the right one it just automaticaly loosens the left because it is the free one! I have tried WD40 to ease it but to no avail ARGHHHHHHHHH
Why oh why do thy not use a spindle type system !!!!!! :evil:
Any help asap please
Old 05-18-2006, 08:36 AM   #2 (permalink)
Favourite Bike: 01 Tiger
Other Motorcycle: 02 Sprint RS
Extra Motorcycle: another 01 Tiger
On mine I loosen the left hand bolt most of the way use it to push the axle out the right side. Then remove the left bolt and slip the axle out the right hand side. Also My bike is 19mm one side and 22mm on the other side. I think you are OK just confused
nortoncharlie is offline
Old 05-18-2006, 08:49 AM   #3 (permalink)
Fizzy
LOL not confused just frustrated
Mine are 19mm both sides unless the socket set is engraved wrong :???:
I will go out to the garage now and try your suggestion trying to keep the BIG HAMMER on the workbench (for now)
I'll be back Cheers
Old 05-18-2006, 09:07 AM   #4 (permalink)
Fizzy
Just an update
Thanks NortonCharlie for you help .... I was confused ... but not about the nut sizes.
I got confused thinking that because a bolt came out of the left side I also thought that the right would be exactly the same ..... thus I thought that there was no spindle going all the way through as is usual on any bike I had before so you can imagine my surprise when I followed your advice and ended up with a strange bolt "into" bolt setup and not the usual nut "onto" bolt setup hahahaha confused yet yourself.
Many thanks Rat forum for getting me a place to get my headache relieved without alcohol :-D
Now going to get that new rubber on WAYHAYYYYYYY
Old 05-18-2006, 01:31 PM   #5 (permalink)
Glad it all worked out. It can be a trick getting it all back together mostly a matter of not dropping the spacers when getting the wheel back into position. I sometimes pull the rear caliper so I have one less thing to line up, but it isn't necessary. I usually dab a little grease on the spacers to help hold them in place and lube the seals.
Old 05-18-2006, 02:55 PM   #6 (permalink)
Fizzy
Thats exactly what I done although next time I will get a helping hand to help align everything as it was a curse every time the caliber side spacer keep dropping out when touched even with a dab of grease
Thanks again.
Until next time Cheers :chug:
Old 05-19-2006, 12:33 AM   #7 (permalink)
AVM
I use a ratcheting tie down strap over the seat and through the wheel to help lift and hold the rear wheel in place while putting in the spacers and axel. Makes it a lot easier when you don't have another person around to help.
AVM is offline
Old 05-19-2006, 02:24 PM   #8 (permalink)
Fizzy
Wish I had read that suggestion before I started :knkknk:
But it will be stored for next time Thanks
2001 955i Rear Wheel Hub Crack Flyinglard Tiger Workshop (archive) 3 02-15-2008 06:45 PM
2004 Daytona 955i Rear Wheel Smittypro Daytona Deliberations 3 12-05-2007 01:39 AM
size of front wheel axil/spindle allen bolt 2000 st? stwanted Sprint Forum 4 03-20-2007 06:33 PM
Rear wheel banging around - Watch that rear axle nut! n578md Twins Technical Talk 6 09-17-2006 02:49 PM
Rear seat bolt DreamWeaver Twins Technical Talk 6 07-12-2006 10:30 PM
