Surging and Hunting - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-07-2006, 01:27 PM   #1 (permalink)
2006 Tiger, 2000 miles.
I find that when riding through towns at slow speeds, under very little load, the bike can be prone to surgeing. Also, when hot, the engine will hunt slightly when at tick over at lights etc.
I know this is classic fuel injection characteristics and my old BMW r1100gs was worse, but that was on an early injection system.
I would have though present day systems would be much better. Certainly no problems under load.
Does anyone else notice this? Or is it just me/my bike. I know that Suzuki will often load a different ECU program if you presented with similar complaints on their bikes.
Any feedback welcome. Otherwise, smashing bike Grommit!
krull is offline
Old 05-07-2006, 01:53 PM   #2 (permalink)
Favourite Bike: 2011 Speed Triple
Hi Krull,
Most of us with newer Tigers suffer from this. Do a search for "surging" in the Tiger forums and you'll find loads of info. Also look for O2 sensor, as this has cured it for lots of people
Russ
Russ
Sofalofa is offline
Old 05-07-2006, 03:57 PM   #3 (permalink)
Put on a Happy face.
Sofa has covered it really.
Were it gets complicated is if you can't find the info,there have been loads of 'Tunes' over the years(since99) just because you've got the latest one doesn't mean it's the best!!!which you can have downloaded at your dealer.
Some dealers are very good with the Tune info others haven't got a clue.
All the triples hunt to a degree,a combination of the 'Tune' installed,the general tune of your Tiger,and if your still not happy try an 02 sensor of which war and piece has been written!!!!
winger is offline
Old 05-07-2006, 04:19 PM   #4 (permalink)
Cured the problem by running track can program with standard can. This after advice from Hinckley.
Not legal, but richens the mixture a little and therefore gives the engine an easier time.
Timian is offline
Old 05-07-2006, 06:49 PM   #5 (permalink)
Nice one Timian, didn't know about that. Mine still surges like that "running out of fuel" feeling when filtering. Bike's about to have its 12,000 mile service so will ask 'em...
[ This message was edited by: Sofalofa on 2006-05-07 16:50 ]
Russ
Sofalofa is offline
Old 05-07-2006, 10:40 PM   #6 (permalink)
O2 sensor helped a bit with me, but next time im under the tank ill take it back out. i realy miss the over run poping
Interesting about the race map on std can. was thinking of doing that anyway next time im at a dealers because i will add a can soonish.
ghostbiker955i is offline
Old 05-08-2006, 08:28 AM   #7 (permalink)
Favourite Bike: Tiger1050
chrisn's Avatar
Other Motorcycle: 1050 Speed Triple
Krull,
Ask your dealer to reinstall the tune and balance the throttle bodies - this cured it for me on my last Tiger.
Chris
chrisn is offline
Old 05-08-2006, 03:41 PM   #8 (permalink)
I've never noticed the problem, in both standard form or Can and K&N with race tune.
It's got to be something other than the tune. I would guess throttle bodies.
nobby400 is offline
Old 05-08-2006, 04:15 PM   #9 (permalink)
Interesting relpies thanks. So it's not just me then. As the bike only has 2k miles, I would like to (innocently) think that the trottle bodies are balanced....
[ This message was edited by: krull on 2006-05-08 14:18 ]
krull is offline
Old 05-08-2006, 11:29 PM   #10 (permalink)
Diego's Avatar
Been a while since we had one of these threads, mercifully. Most Tigers do 'hunt' a little, and it's mostly not a problem.
In cases where it really is more bothersome, you'll quickly notice that the O<sub>2</sub> sensor removal is the quasi-official religion of this particular message board.
But going open-loop only hides the problem; it doesn't actually cure the underlying cause. The true cause is sometimes a faulty sensor, and replacing it with a new one restores normal operation. More often it indicates throttle body imbalance or air leaks, which can still somewhat impair the engine performance even if the RPM stays more constant after blinding the engine management system to the exhaust gas errors. And, as also mentioned, it can be the wrong fuel injection map causing too-lean burning.
Do as you wish, but personally, I'd rather know when there IS a problem and try to actually fix it.
[ This message was edited by: Diego on 2006-05-08 21:32 ]
John
Diego is offline
Hunting For Sporting Goods mistermellow001 Biker Hang-Out 1 02-10-2008 02:16 PM
Buzzing/hunting at steady throttle opening? Jonny955 Tiger Chat 5 09-21-2006 08:16 PM
'Hunting' at idle brittour95 Tiger Workshop (archive) 9 02-10-2006 08:18 PM
Tiger Hunting winnwillinger Tiger Chat 10 01-04-2006 01:22 PM
