On 2006-05-04 13:25, BaldEagle wrote:
TiggerTwo read this thread think its what you're asking,
Electrosport replacement stator :wink:
Thanks BaldEagle. I PM'd and replied to their posts a couple days ago. Meanwhile I've found 3 sources for the stator and R/R.
I have the part numbers and the technical data I needed. Now I'm deciding whether I want to do it or not.
I have contacted Triumph UK twice regarding the ACTUAL power available for additional accessories, such as heated gear or driving lights, etc...
They only commit to the rating as specified at the accessory plug. so 10A fused = 120W.
Of course that's after all the stock system consumption such as headlights, turn signals, ECU, Fuel pump, heated grips etc...
So what the Tiger is left with off the stock alternator and regulator is 120W.
For me that is sufficient for a couple extra 55W PIAA's and 10W worth of heated gear.
The G-175, RR-49(electrex stator, r/r pn's) or
the ESG571, ESR503 (ElectroSport pn also called ElectrexUSA stator, r/r pn's) This system supposedly provides and supports a 30 - 40 % increase in available power.
The folks, here on the forum, that have installed them have had failures in the past posts. I am awaiting their current opinion since the subject matter hasn't been brought up for a while. Perhaps it worked out for them.
I'm awaiting their replies...
Thanks - Walt
[ This message was edited by: TiggerTwo on 2006-05-04 14:59 ]
