Brakes & Dashboard - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comOntario Tourism
Old 05-04-2006, 12:11 AM   #1 (permalink)
JRO
Favourite Bike: 06 Tiger
JRO's Avatar
Other Motorcycle: 07 FJR 1300
Extra Motorcycle: 07 R3 Tourer
Almost 6,000 on my '06, and already I need rear brake pads. This is embarassing, to me. I'm not heavy on rear brakes - front brakes are what mostly brings you to a stop. Makes me feel like some amature, weekend rider on his Boulevard cruiser.
Oh, well. To sinter, or not to sinter?
In any event, I still have no real complaints about this bike. I am very happy with it. However, today I noticed something odd while washing the bike: There are two spots on the dashboard that appear to be heat-melted. They are both near the warning light array. Is this unusual, for a Tiger? Seems to me the warning lights are either too hot for the dash, or there could be shorts in the wiring. Anyone else seen this?
JRO is offline
Old 05-04-2006, 01:36 AM   #2 (permalink)
djr
I have an 03 (had an 03) and no heatspots and still on original pads at the rear
David
My Photo Album
My Tiger pages
djr is offline
Old 05-04-2006, 01:57 AM   #3 (permalink)
Favourite Bike: Tiger 1050
It is unusual to wear out the rear pads so quickly. After 18,000 miles I'm still on the original pads. I suspect that your rear caliper is sticking causing the pads to wear prematurely.
I suggest you go for a ride and stop after a while without using your rear brake. Check to feel if the rear disc is hot. If it is you know that the pads are rubbing.
I don't have any hotspots on my dashboard. I'd get the dealer to check it out.
adrianmol
Link to my Tiger 955i & 1050 Website.
adrianmol is offline
Old 05-06-2006, 03:59 PM   #4 (permalink)
Favourite Bike: Triumph 955 Girlie
tigertales's Avatar
Extra Motorcycle: 1968 Honda CT90
I ride in So Cal stop n' go traffic and rear pads were at 10% at about 4000 miles. I do use the rear brake, especially when approaching a corner so my conclusion was, this is the issue. I have no corrosion around the rear caliper and at the time of pad replacement the caliper moved smoothly on the guide pins.
Regarding the distortion of the plastic dash around the warning lights, I did experience a problem on my dash and replaced it. Now, that said - 1 month later it had some distortion occur on the second dash.
I can only offer my bike was parked ourside and during the period after the 2nd replacement, I noticed the sun shined through the screen and focused a hot spot about where the distortion occured. I have pictures in my Tiger dash in the Tiger Album, I believe in cockpits & screens - I show the old and new dash for comparison.
Now, I cover the dash with a white shop rad whenever parked outside. So far it has not gotten worse.
With no change since the rag technique, my conclusion is that it is from sun heat magnified by the windscreen.
tigertales is offline
Sprint dashboard globes Diz T3 Sport / Touring Forum 4 03-15-2007 10:16 PM
brakes! mag10 Twins Talk 10 06-21-2006 09:30 PM
better brakes cafestyle Club Cafe' 30 07-15-2005 09:36 AM
Brakes Maintenance & Workshop Talk 4 04-17-2005 07:28 PM
Brakes dolson Maintenance & Workshop Talk 9 03-29-2005 07:50 PM
