front brakes - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!
Old 05-03-2006, 09:09 AM   #1 (permalink)
the front brakes on my 05 tiger are pulsing and real shaky on stops, I guess the rotors are bad, but with only 4000 miles??
Anyone had similar problems and what is the fix?
Also, the left side (shifter side) of the oil pan seems to be leaking a bit....anyone experience that too?
Thanks
tiger-rover is offline
Old 05-03-2006, 11:06 AM   #2 (permalink)
:???: DODGY ROTORS,(DISCS) LOADS OF THREADS RELATING TO THIS. WARRANTY JOB I THINK, SOME ARE ON THERE 3RD SETS!!!
God Bless Tiger and all who ride her.
BaldEagle is offline
Old 05-03-2006, 12:31 PM   #3 (permalink)
ipg
Yip, third set for me, originals lasted 6000 miles, replacements another 6000 miles. Do you see a pattern starting to form here. Although next time I'm out of warranty and might not be so happy. :evil:
IPG
Keep it rubber side down!
MyPhoto Album
ipg is offline
Old 05-03-2006, 03:34 PM   #4 (permalink)
Thanks
Check your water pump and the screws for it. There are two M6 screws and threads are only 5-6 mm long in aluminum. It can easily be removed with houses on. There is a O-ring inside for sealing oil inside and the hole in is about an inch wide. you don“t have to open the water pump.
I had to fix mine threads, one screw where loose and threads where gone. :evil: Mine did not leak but I think it could have happened if I did`t fix it.
Anders
doitright is offline
Old 05-03-2006, 10:44 PM   #5 (permalink)
Favourite Bike: Tiger
Other Motorcycle: 89 Moto Guzzi Mille
Extra Motorcycle: 67 BSA 441
Mine went bad after 2,000 miles and both were replaced under warranty. The disk metal was defective and I am hoping the replacements are a different quality. Well, there is always hope... :roll:
Sometimes it takes a whole tank before one can think straight
Anthouse is offline
Old 06-07-2006, 01:03 PM   #6 (permalink)
Lovechops
I also needed mine swapping after 2000 miles, I see a pattern forming here.
My Triumph dealer told me there had been a bad batch of discs released. We shall see as I wont be happy if they go again!
Old 06-07-2006, 05:03 PM   #7 (permalink)
Favourite Bike: 2011 Speed Triple
new pair at 1,000 miles
3rd pair at 6,000 miles
Just had 12,000 mile service and the disks are fine. Was VERY worried about it being on the 3rd set by 6,000 miles, but they've been fine since then. Done under warranty without question...
Russ
Sofalofa is offline
Old 06-08-2006, 02:39 PM   #8 (permalink)
.. and "knocking fork's" ... wonder if there's a relationship?
Curious - are most of your travels on unimproved roads?
And, regarding "...Was VERY worried about it being on the 3rd set by 6,000 miles, but they've been fine since then."; did they happen to replace the caliper housing on the third go around as well?
Walt
[ This message was edited by: TiggerTwo on 2006-06-08 13:20 ]
OAK
TiggerTwo is offline
Old 06-09-2006, 12:02 PM   #9 (permalink)
tiger_ryding
Yes, my experience was similar.
I had pulsing in my front brakes and it was the rotors, which were replaced under warranty. To their credit, Triumph did this without question and turned this around very quickly. My brakes feel so much better now.
Somewhere there is a previous thread on this.
Old 06-16-2006, 02:19 PM   #10 (permalink)
Favourite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
I perceived a pulsing in my front brakes after reading all the horror stories (power of suggestion?). That prompted me to try a set of EBC's floating rotor conversion. Way cool and about half the weight of stock. Aluminum carriers with stainless rotor. Anyone need a set of stock rotors that may or may not be warped?
tyrebyter is offline
Shaking front end when applying front brakes. stealthy1 Daytona Deliberations 10 11-23-2006 05:34 PM
%*&$#! My Front Brakes Are Going! Aske Sprint Forum 10 10-28-2006 12:49 PM
Front Brakes, again! b50bsa Sprint Forum 31 06-11-2006 04:08 AM
Front Brakes Bort The Rocket Science Forum 1 01-19-2006 12:36 PM
FRONT BRAKES vanpraag Sprint Forum 8 12-08-2005 09:47 AM
