afraid ,you will have to take the front wheel of,and check the speedo drive,its made out of a type of ceramic,and if it cracks,or gets badley worn (grease well when replacing),the speedo becomes erratic,a new speedo drive complete,inc cable is £45.00 from triumph,but if you buy one secondhand,check its not to worn.
as you put it all back together,make sure the lugs line up,otherwise you will will smash it again (been there,done that!!) :-D
