Ignition barrel - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 9 (permalink) Old 09-21-2010, 03:24 PM Thread Starter
Main Motorcycle: Street Twin
grizzly adams's Avatar
Other Motorcycle: Tiger 800Xc
Extra Motorcycle: 2010 Speedy Matt Khaki
Ignition barrel
Anyone know if just the electrical part of ign barrel is available as key works ok on mine but you sometimes have to flick the key on/off a few times to get the ign/start up also with Triumph modular construction would a 06 Sprint ign barrel be the same as 05 Tiger
grizzly adams is offline
post #2 of 9 (permalink) Old 09-22-2010, 12:46 AM
Main Motorcycle: 2007 Triumph Tiger ABS
EvilBetty's Avatar
Other Motorcycle: 2005 Triumph Tiger - SOLD
Send a message via Yahoo to EvilBetty
Nope, you'll have to replace the entire module.
Who doesn't like additional keys?! My 955i has 4!
There's no place like 127.0.0.1...
2005 Triumph Tiger - Lucifer Orange - SOLD
2007 Triumph Tiger - Jet Black
EvilBetty is offline
post #3 of 9 (permalink) Old 09-26-2010, 05:42 PM
Main Motorcycle: 2006 Triumph Tiger 955i
Other Motorcycle: previously 2002 tiger 955
Hi, I have had problems with the electrical side of my ignition switch, resulting in losing indicators, horn and brake lights, it took a little while to find, due to being intermitant. By twisting the key against the ignition contacts with a 'jiggle' would get everything back working again. I sprayed some electrical contact spray into the ignition barrel and worked the ignition a few times and,"touch wood" it is working fine at present. I will probably have to replace it eventually, but work on the idea that a drop of routine maintenance may keep it going for a bit longer.
Mark T is offline
post #4 of 9 (permalink) Old 09-27-2010, 01:53 PM Thread Starter
Yeah I have already soaked it in any hole and thru Key slot with wd and left it so I might be lucky, been too damp yesterday and today to try
post #5 of 9 (permalink) Old 09-28-2010, 05:54 PM
All the best and fingers crossed then, "touch wood" mine is behaving at present, regards, Mark
Mark T is offline
post #6 of 9 (permalink) Old 09-28-2010, 07:22 PM
Main Motorcycle: T160
Other Motorcycle: harley Night rod 2006
Extra Motorcycle: Buell 1125CR
Had a problem just like yours. With some care you can take the back off the covers the wires where they attach the contacts. On mine a contact had come off and the bike would switch on and off when turning the bars.
Resoldered and all is good. Worth checking as Triumph over charge for their electrical items.
usanigel is offline
post #7 of 9 (permalink) Old 10-01-2010, 10:50 AM
Main Motorcycle: 2003 Tiger 955i
Other Motorcycle: '99 Striple 955i
Extra Motorcycle: '72 BSA B25FS,'53 AJS 18S
Thumbs down
After an ignition power glitch or two earlier this year; wiggle key and then it worked, I thought I'd be alright too. I ended up calling for recovery when I was in the south of France...
ChazzyB is offline
post #8 of 9 (permalink) Old 10-01-2010, 02:46 PM Thread Starter
Ooops sorry to hear that
post #9 of 9 (permalink) Old 10-03-2010, 06:20 PM
Red face
Sounds like I'd better check it out before it develops into a big problem rather than an intermitant niggle!
Mark T is offline
like a big ol 4 barrel dogeddie Air Cooled Twins Technical Talk 2 03-20-2010 09:44 AM
Pistons in the barrel HankQ Classic, Vintage & Veteran 7 05-13-2009 09:16 AM
Ignition barrel kevoz Tiger Workshop (archive) 5 01-21-2007 07:20 PM
remove ignition barrel from ignition switch? kanoa Classic, Vintage & Veteran 3 07-13-2006 12:50 PM
Ignition Barrel GONE Hinckley Classic Triples 2 08-27-2004 07:05 PM
