front brake line - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleHonda Powersports Motorcycle.comSportbikeTrackGear
Old 11-06-2009, 08:00 PM   #1 (permalink)
Favourite Bike: 2001 triumph sprint st
gumbytwo's Avatar
Other Motorcycle: yamaha yamahopper
front brake line
Hello all- I'm over from the Sprint side and wondered if any of y'all know if the front brake line from a Tiger bolts up to a Sprint and if it's longer than the one OEM on my scotter. I installed Gen Mar risers in the spring and although the line is long enough to work it seems to be maxed out as for as length goes- I don't like the way it is right now. Any info on this subject would be appreciated- I ride an '01St, Thanks in advanced.
gumbytwo is offline
Old 11-09-2009, 07:18 PM   #2 (permalink)
blacktiger's Avatar
Should bolt up OK as the unions are pretty universal. However, why don't you get Goodrich to make up a set to exactly the length you want?
You only live once, so enjoy it.
'02 Tiger955i in black.65000 miles.
'12 Tiger800XC in black. 11500 miles.
http://s396.photobucket.com/albums/p...55tiger/TIGER/
blacktiger is offline
Old 11-10-2009, 08:04 PM   #3 (permalink)
gumbytwo's Avatar
thanks Blacktiger, over on the Sprint side they talked me into the same thing, thanks again.
gumbytwo is offline
front brake line gumbytwo Sprint Forum 16 11-09-2009 09:54 AM
TBird Front Brake line? funhunter63 Hinckley Classic Triples 1 04-04-2008 01:36 AM
Front brake line clips not holding MotoZiggy Speed Triple Forum 13 03-26-2008 04:39 PM
Front Brake Line htown16 Classic, Vintage & Veteran 8 10-18-2007 08:11 PM
does anyone know if the speedmaster front brake line is.... HacksawsGarage Twins Technical Talk 0 05-12-2007 02:15 PM
