Throttle adjuster - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-21-2009, 12:13 PM   #1 (permalink)
brw
Throttle adjuster
955i 2005 cast wheels.
I have a broken "plastic" throttle adjuster (twist grip end). Any solution other than a new cable?
Not keen on removing the tank is why I ask.
Your suggestions welcome.
Brian
brw is offline
Old 10-21-2009, 09:19 PM   #2 (permalink)
Favourite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
You'll need to replace the cable, but removing the tank isn't as big an issue as you think. You don't need to remove the fairing, just the seat, battery and the tank. You may even be able to get away with just lifting it a bit, but don't be afraid of it.
Take your time, even take photos as you go so you can check your work in reverse when you put it back together.
Mick.
My Album
miker is offline
Old 10-22-2009, 07:14 AM   #3 (permalink)
brw
Thanks for the info. Miker
My problem with the removal of the tank stems back to when I fitted an Oxygen eliminator earlier this year. It seems that every time I need to remove flexible fuel lines etc on a vehicle they are secured by a different type of "clip". I could not easily release those on the Tiger and resorted to lifting the tank and managed that way. Was not particularly happy with that method, but it worked. (by the way slow filtering is greatly improved without any obvious problems). I would prefer to remove the tank when replacing the throttle cable, how do the clips release?
Brian
brw is offline
Old 10-22-2009, 11:47 AM   #4 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
I must say that stupid little plastic adjuster is one of the few Tiger parts which are really poorly designed. For the sake of a few pence they could have put a proper metal one on. Mine is always slackening off and giving too much free play.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 10-23-2009, 01:44 AM   #5 (permalink)
miker's Avatar
Brian
You're welcome. Last time I looked at mine, there were no male/female quick fits, just a hose clamped on to the side of the fuel pump housing and a couple of wires. Mine is also a cast wheel job, but I haven't a photo to show you.
If you still have the quick fits, you need to push the small button kind of thing on the side, this releases the male section. Beware putting them back, that you don't chew out the o-ring.
Manual time methinks...
Mick
My Album
miker is offline
throttle cable adjuster assembly keeefy2000 Tiger Workshop (archive) 2 06-12-2008 03:28 PM
Mikuni throttle adjuster screene T3 Sport / Touring Forum 8 03-10-2008 01:23 PM
05 06 clutch adjuster ? rckrzy1 Speed Triple Forum 5 08-04-2006 01:20 PM
Preload adjuster? doitright Tiger Workshop (archive) 1 08-14-2005 05:54 PM
Broken throttle cable adjuster? robadele Sprint Forum 2 09-17-2004 05:20 PM
