Cover gaskets - to goo or not to goo? - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com Classifieds!
Old 10-20-2009, 05:55 AM   #1 (permalink)
Favourite Bike: 2003 Tiger 955i
Other Motorcycle: '99 Striple 955i
Extra Motorcycle: '72 BSA B25FS,'53 AJS 18S
I'm assisting a chum who took to the countryside on his Tiger last week-end. As a result, the right-side crankcase end cover is, shall we say, past its best and needs replacing. Once a new cover and gasket(s) are on hand, should a jointing compound be used? I've suggested a thin film of Hylomar, but it looks as though there was nothing used at the factory. What's the recommendation? Mr Hayne's publication just says "use a new gasket" - Hah!
ChazzyB is offline
Old 10-21-2009, 11:00 AM   #2 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
I'm a great fan of Wellseal - a very thin coat applied with a paintbrush. Works well on the Velo. But modern machining & metals are very good. I haven't replaced that particular gasket but did put the recommended thin smear of silicon on the cam cover when I checked the valves a couple of years ago and that seemed to work fine.
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 10-26-2009, 07:53 AM   #3 (permalink)
Favourite Bike: Tiger 955i
Patman1200's Avatar
Other Motorcycle: Bandit 1200
Extra Motorcycle: Yamaha TTR250
I always use a very thin amount both side of the gaskets. Belts and braces me as I hate oil leaks.
I had to remove that cover last year and used a new gasket and Hylomar.
Pat
Somewhere in Hampshire
Patman1200 is offline
Old 11-02-2009, 02:33 AM   #4 (permalink)
Favourite Bike: 2007 Triumph Tiger ABS
EvilBetty's Avatar
Other Motorcycle: 2005 Triumph Tiger - SOLD
I've used nothing on the valve cover or alternator cover and have no leaks. Reused the valve cover gasket. Had to use a new alternator gasket due to the small amount of sealant used for the stator wire grommet.
There's no place like 127.0.0.1...
2005 Triumph Tiger - Lucifer Orange - SOLD
2007 Triumph Tiger - Jet Black
EvilBetty is offline
exhaust gaskets simlog T3 Sport / Touring Forum 2 09-16-2009 08:18 AM
gaskets or sealer keystiger T3 Sport / Touring Forum 8 03-30-2009 01:14 PM
Gaskets! KitNYC T3 Sport / Touring Forum 9 02-07-2008 03:16 PM
gaskets customcafe Club Cafe' 8 11-25-2006 01:13 PM
Manifold gaskets quagmire Classic, Vintage & Veteran 3 10-21-2005 12:51 PM
