tiger 1050 oil/oil filter?? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-14-2009, 02:31 PM   #1 (permalink)
I need to get ready to change my 1050's oil and filter. What is recommended? Where is a good place to buy the filters?
Thanks for your insight(s).
Mr. Pete---->
aging hippie
mrpete64 is offline
Old 10-14-2009, 07:59 PM   #2 (permalink)
KuzzinKenny's Avatar
If yer bikes still under warrenty you`ll need to fit a Triumph filter !! it helps if you put in yer profile what side of the pond yer on !! i get stuff from here............
http://www.triumph-online.co.uk/index.asp
but its no good if yer overseas !!
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Old 10-14-2009, 10:46 PM   #3 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
If you are in the USA, one can do their own maintenance AND use parts other than the ones the manufacturer puts his name on without affecting the warranty. I recommend keeping receipts for your parts purchases.
The amount of oil to fill with filter change: 3.2 liters...the full mark is the mark touching the top of the cross-hatch lines, and not the mold mark about 1/4" above the full mark. A simple way to check oil is to pull the dip-stick while the bike is on the side-stand, clean the dip-stick and replace it--screw it all the way in. From one side or the other, pull the bike to vertical and hold it for a few seconds in the vertical position. Lower it onto the side stand and remove the dip-stick and read the oil level. I have never gotten a different reading whether the bike is hot or cold, but the instructions are to check it with the engine hot and after it has set a few minutes to let the oil drain back to the sump.
Filters: Look at the cross-reference info on www.calsci.com
There are many places to purchase filters--even Walmart has them in the USA.
Oil specs listed by the manufacturer: "Semi or fully synthetic 10W40 or 15W50 motorcycle oil which meets specification API SH (or higher) and meets JASO MA, such as Mobile 1 Racing 4T".
Torque values: Sump plug: 25 Nm (Do not over-tighten--a few have cracked the sump).
Oil Filter: 10 Nm If you do not have a torque wrench, hand tighten about like one does on an auto.
Fill the oil filter prior to installing--this takes a few times topping it off to get it full.....
Larry
RedBird is offline
Is the gearbox on the 1050 Tiger different from the 1050 Sprint? bareyb Tiger Chat 15 03-21-2011 06:34 PM
K&N Filter for 1050 S3 is KN-204, not KN-191 twizimism Speed Triple Forum 2 03-06-2009 02:08 AM
Air Filter for the 1050? VonKujo Speed Triple Forum 4 07-02-2007 02:01 PM
K & N Filter Available for 1050 wills Sprint Forum 5 07-08-2006 09:42 AM
oil filter for 1050 S#? FrankP Speed Triple Forum 1 03-17-2006 03:04 PM
