Cutting Out when hot ! - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGear
Old 09-18-2009, 09:20 AM   #1 (permalink)
Newbie
Unhappy Cutting Out when hot !
Hi -new owner with a 1996 Tiger which is lovely but very frustrating ! Bike starts fine when cold but after about 10 miles or so it cuts out - no spark but the starter motor turns over fine, battery and all electrics work ok. Leave it 20 mins and it starts up again no problem.
I've already changed the ignition sensor and used a different CDI - all to no effect.
If the side stand switch was faulty would the starter motor still work ??
Any suggestions gratefully received !
esmyth is offline
Old 09-18-2009, 09:28 PM   #2 (permalink)
KuzzinKenny's Avatar
Hey esmyth !! Welcome to the Tiger forum !! i`ve never owned a 96 model Tiger but i think there`s a post here about the coils packin in when hot !! try doing a search and see what comes up !!
good luck !!
KK
ps you might get some info here.... http://www.tigertriple.com/forum/index.php
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Old 09-27-2009, 01:24 PM   #3 (permalink)
Favourite Bike: 98 steam driven Tiger
Other Motorcycle: CRFX 450 honda
Extra Motorcycle: 95 steam driven tiger
It's the ignition pick up sensor on the RHS crankshaft , cost is about 70 US Dollars and you need to set the air gap to the timing disc to be about the thickness of a match book .
Your tigger will be a happy camper when you replace it .
mustang is offline
Cutting out Hazza Triumph SuperSports 4 08-12-2008 01:56 PM
cutting out greasygraeme Speed Triple Forum 6 06-21-2008 09:48 AM
03 Cutting Out tcowjww Tiger Workshop (archive) 8 05-02-2008 03:07 AM
Cutting Out brianre Tiger Workshop (archive) 7 08-25-2007 10:37 AM
99 TBS cutting out syncromash Hinckley Classic Triples 1 06-10-2007 09:23 PM
