What you are describing is very much normal for the '07 Tiger. My fan comes on after the 7th bar has been on about 30 seconds.
When I am parking Tiger, I always look at the temp before I shut off the bike--if it is at 7 bars, I wait a couple of minutes for the fan to cool it down to 6 bars before I shut off the engine. The Tiger 1050 fan works ONLY when the ignition switch is ON.
An '07 should have had the coolant changed and flushed a couple of times by now. Inspect your coolant overflow tank for coolant color and deposits. If your coolant is not of a good color and clear enough to see through easily, I would change and flush the system.
Larry
