Judder when braking - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda Powersports Motorcycle.com Classifieds!Ontario Tourism
Old 08-25-2009, 10:16 AM   #1 (permalink)
Judder when braking
When I brake I get a considerable amount of juddering coming up through the bars. It is speed relative almost as if I had something catching on the disc on every rotation. Braking really slowly I can almost certainly feel that there is an inconsistency. Holding the lever with the same pressure develops the judder but more noticeably it seems to have a gripping point followed by the normal braking then a quick grip and so on, fast enough to be related to the disc. Looking at the discs they seem fine, all bolts are tight and the disc appears smooth. Taking the Calipers off the brakes all look fine they are relatively new and the pistons work just fine, plenty of braking fluid.. I was thinking just to replace both discs but if you have any other ideas? Do I need to replace the brakes now or could it be something else?
Fray Bentos is offline
Old 08-25-2009, 11:23 AM   #2 (permalink)
Put on a Happy face.
Warped discs i'm afraid,'They all do that Sir'
If the bike is out of warranty,look for aftermarket like EBC.
winger is offline
Old 08-25-2009, 12:14 PM   #3 (permalink)
They int cheap are they?? £250 for the aftermarket floating ebc ones.. Anyone know a cheap supplier.. Can import through the company if it works out better..
Old 08-25-2009, 03:02 PM   #4 (permalink)
I'll tell you a cheap supplier of discs Triumph!!!,how they get away with it i'll never know,on par with their plastic fuel connectors.
winger is offline
Old 08-25-2009, 07:38 PM   #5 (permalink)
Favourite Bike: Bette 99 Tiger
You could always give Triumph-ant a bell, they sorted a guy out on another forum with the same problem - different bike tho.
PeteH is offline
Old 08-27-2009, 05:29 AM   #6 (permalink)
Triumph aren't the only culprits. BMW have the same failure rate.
It's hard to know whether it's cheap manufacturing, materials or assembly.
I think I've mentioned before, there's probably more bikes out there with
warped discs but the owners don't realise it's a fault.
Pickaxe is offline
Old 08-27-2009, 06:14 AM   #7 (permalink)
Favourite Bike: 955i Tiger
Other Motorcycle: ex. Kwak Zephyr 750
Extra Motorcycle: 1050 Speed Triple, I wish
Yip, warped discs
Not sure what effect a warped disk will have on the other brake components if you don't change them but beware that they will fail an MOT "if its easy to feel the judder" according to my MOT place. There is an official variation value on the braking capacity but I can't remember what it is.
I had mine replaced after some scumbag knocked my bike over in a work carpark then buggered off !"£!£$"£%$. Anyhow, the insurance replaced the discs (and all the other bits) but the new ones warped within about 1500 miles. Performance Triumph in Swindon replaced them at no cost and the new ones have been fine.
They did say that it wasn't that unusual although 1500 miles was very low. Its happened on other models too.
I must say that Performance Triumph have always been great with service and support.
- The more I ride 'er, the more I luv 'er -
jimbo2807 is offline
Old 08-28-2009, 04:21 AM   #8 (permalink)
I've just had a new rear disc replaced on my works BMW and it's warped within two months (1000 miles). That's why I think it's sometimes down to assembly.
BTW, the bikes already had two sets of front discs due to warping in its 25K life and it's not unique on the fleet.
If the fitter torques down the bolts unevenly, or doesn't clean up the locating surfaces, it doesn't take much to warp the disc.
The discs on my 06 Tiger were replaced after 5k, although they were probably shot well before that mileage. They've now done a further 5k without problem.
Incidentally, when I first reported the problem to the dealer, they said that the run out wasn't sufficient for Triumph to replace under warranty. However, with a little friendly persuasion, the dealer relented and exaggerated the problem to Triumph.
Pickaxe is offline
Old 08-28-2009, 09:04 AM   #9 (permalink)
oldrider's Avatar
My 06 Tiger has had three lots of front disks replaced within the warranty and have now got the same problem outside of the warranty!
Triumph have come to the party and are replacing them again!
While I applaud Triumph for their support outside the warranty, I want the problem fixed, once and for all!
Have any of you used aftermarket floating disk replacements?
If you have, where did you get them and how are they performing?
I believe the same problem exists on another Triumph 955i sports model of the same vintage too.
I really enjoy my Tiger and am not too ham fisted with the brakes but I don't soft peddle the bike, I bought it to use to it's full capability.
Perhaps that should read, "to my full capability" rather than the bike's! (there is probably quite a big difference)
Blue 2007 Tiger 955i . (referred to as the 06 model) British specification.
oldrider is offline
Old 08-28-2009, 11:19 PM   #10 (permalink)
Favourite Bike: Tiger
Other Motorcycle: 89 Moto Guzzi Mille
Extra Motorcycle: 67 BSA 441
It's an old problem but it is new to everyone who has it. Hard to say why some bikes get it and some don't. I heard quite a few suppositions about cause and effect but after my 05 went through three front disk sets in three years Triumph finally, with some nudging, replaced the front wheel. I haven't had a problem since.
Sometimes it takes a whole tank before one can think straight
Anthouse is offline
judder? millwallfcuk Trophy 7 11-09-2008 02:38 PM
Tiger 1050 clutch judder. It's a long story... chrisell Tiger Chat 3 07-22-2008 04:37 PM
2005 Tiger front brake judder Rob Gibbons Tiger Chat 5 04-08-2008 05:08 AM
Braking twisted Sprint Forum 3 10-12-2007 12:53 AM
Front brake judder barns Tiger Chat 2 04-06-2004 04:51 PM
