How do you lift a Tiger - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.com Classifieds!Ontario Tourism
Old 08-14-2009, 10:23 PM   #1 (permalink)
Favourite Bike: 06 Tiger
Went to Harbor Freight, bought a hydraulic lift...
I got home and realized that the whole bottom of the Tiger is exhaust. How the hell do you get it to sit on a lift and work on it?
Fe Man is offline
Old 08-14-2009, 11:12 PM   #2 (permalink)
Favourite Bike: Triumph Tiger '05 BRG
Other Motorcycle: there are others?
Extra Motorcycle: on the hunt for one.....
Haven't done anything that couldn't be done from the centerstand.....including entire motor removal and install on my sprint...
However I have seen pics of ratcheting tie straps from ceiling joists used to hold the beast up.
The difference between genius and stupidity is genius has its limits
keystiger is offline
Old 08-14-2009, 11:14 PM   #3 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
Sounds like a jack to me--I bought a Sears jack and used it once on my Bonneville. The jacks are too unstable for me to work on a bike while on the jack.
I bought a bike lift that you roll the bike onto and it raises the bike about 35" in the air--the bike is still sitting on its tires. There are lifts with removable rear sections for removing wheels. Harbor Freight sells a couple of lifts--one foot operated and the other air operated. Mine is air operated. I bought the Pro Cycle lift from Derek Weaver in Fort Worth, Texas. http://www.derekweaver.com
Larry
RedBird is offline
Old 08-15-2009, 01:55 AM   #4 (permalink)
Favourite Bike: 2006 Tiger
Extra Motorcycle: 1978 Yammer RD 250
I guess I'm fortunate because my business is auto repair and I use my 2 post auto lift to get the Tiger off the ground when needed. To get the rear up I just put 2 of the lift pads under pass. peg mounts (06 model). Getting the front up is a little trickier......remove the upper torx engine mount bolts and replace them with some GOOD bolts about 6-8 inches long and put lift pads under these bolts and lift. Have had the whole bike off the gound about waist high using this method. Of course I realize not everyone can justify the space or $$$$ for a 2 post automotive lift.
p2gee is online now
Old 08-15-2009, 10:20 PM   #5 (permalink)
Guess I need to buy a center stand....
Fe Man is offline
Old 08-17-2009, 12:53 AM   #6 (permalink)
Favourite Bike: '05 Tiger
Other Motorcycle: '71 Norton
Extra Motorcycle: '77 Bonnie
you can use paddock stands. The bars go under the swing arm and lift the whole back of the bike. Can get one to lift the front as well. The shop up in Fort McMurray used it to replace my drive chain. My son uses one to lift his Street Triple R up to lube the drive chain as well cost about $50.00 can. for it. They seem to be the in thing around as most carry them now a days.
clarge is offline
Old 08-17-2009, 08:01 PM   #7 (permalink)
Favourite Bike: Bette 99 Tiger
Check this out
May or may not help, depends on your lift.
http://silver-stripes.blogspot.com/
You could also do a search for the Triumph offers pdf,if thy`re still on. I bought a center stand for my 885 for £14 - 955 ones were £60 odd .
PeteH is offline
Old 08-31-2009, 09:54 AM   #8 (permalink)
Thanks Pete!
Fe Man is offline
Old 09-01-2009, 01:13 PM   #9 (permalink)
Favourite Bike: Tiger
tyger's Avatar
Other Motorcycle: no other necessary
will these work?
I've been wondering the same thing-- how to lift it up so you can work on a tire?
Will these work?
http://www.completehydraulic.com/lif...l#photoGallery
They look a little skinny and unstable but with a security strap or other tie-off it might be ok. Or weld on some braces or new foot pad extension. I dunno... just thinking/asking about.
'05 Triumph Tyger! Tyger! British Racing Green
tyger is offline
Old 09-02-2009, 10:17 AM   #10 (permalink)
I'm building one of these!
Fe Man is offline
Tiger Lift? gbeasley Tiger Workshop (archive) 6 08-26-2007 04:37 PM
Lift Dan18 Classic, Vintage & Veteran 4 08-02-2006 04:30 PM
need a lift CCR Maintenance & Workshop Talk 14 03-18-2006 12:18 PM
How to lift the 05 S3 BubbaZ-Isaac Speed Triple Forum 21 10-12-2005 06:37 AM
How do I lift the S4? DaveC Triumph SuperSports 4 05-06-2005 09:48 PM
