Coolant drain plug 2006 955i ? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-04-2009, 08:47 AM   #1 (permalink)
Favourite Bike: 2006 Tiger '955
Hi All,
Although I think I know where it is, could someone just confirm that the coolant drain plug for the cylinder head is on the front of the engine on the left side piston as you sit on the bike ??
Any tips on how to drain and fill the coolant system without getting any airlocks would be great too. I've done a search.
Would you use distilled or tap water ?
Cheers.
Safe riding.
Regards,
Graeme.
Bike: Tiger 955 (2006)
Tiger-G is offline
Old 08-04-2009, 01:29 PM   #2 (permalink)
Hi Graeme,
Yes confirmed - that is the location. ( checked the manual )
Would personally use tap water. Distilled for battery top ups, usually sealed units now I know.
Can't help with anti airlock procedure, although I've read a very good description somewhere on the forum.
Cheers JJ
johnjo is offline
Old 08-04-2009, 02:44 PM   #3 (permalink)
Favourite Bike: My 06 Tiger
Outrunner's Avatar
Graeme,
Have a wee look through this topic, contains all you need to know........I think!
http://tigertriple.com/forum/viewtopic.php?p=39426
Andy.
Every day above ground is a good day!
Outrunner is offline
Old 08-04-2009, 04:11 PM   #4 (permalink)
thanks chaps, always someone to come to the rescue on here
Safe riding.
Regards,
Graeme.
Tiger-G is offline
Old 08-04-2009, 08:16 PM   #5 (permalink)
How often do you change the coolant on an '06 and isn't there an easier way than all this?
westnash is offline
Old 08-04-2009, 08:30 PM   #6 (permalink)
KuzzinKenny's Avatar
Hey westnash !! this is worth a download..................
http://www.triumph.co.uk/media/enTig...001onwards.pdf
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Old 08-04-2009, 09:09 PM   #7 (permalink)
Favourite Bike: Tiger
Other Motorcycle: 89 Moto Guzzi Mille
Extra Motorcycle: 67 BSA 441
Don't know why Triumph couldn't figure out a drain that doesn't have coolant running all over the engine. Something like a car radiator drain one could attach a hose to.
The bubbles eventually bubble out.
Triumph recommends distilled water in a 50% solution. You can buy it premixed.
Sometimes it takes a whole tank before one can think straight
Anthouse is offline
Old 08-05-2009, 07:38 AM   #8 (permalink)
Favourite Bike: 2004 Tiger 955i
iansoady's Avatar
Other Motorcycle: 1961 BSA Golden Flash
Better than my Land Rover Discovery where you have to take a hose off. As well as remove 2 totally inaccessible plugs......
Ian
2004 Tiger 955i
1961 BSA A10 Golden Flash.
iansoady is offline
Old 08-05-2009, 12:12 PM   #9 (permalink)
The schedule that was referenced above didnt show a mileage to change the coolant or brake fluid. Hard to believe or did I miss something? How often do most do it on the 955 Tiger?
westnash is offline
675 coolant drain chris1bata Daytona675 Forum 7 09-06-2008 12:51 AM
Engine coolant drain plug TIGER1454 Tiger Workshop (archive) 3 02-04-2008 10:19 PM
drain coolant S4 FuryFour Triumph SuperSports 8 04-07-2006 12:42 PM
coolant drain? rat2tymes Trophy 2 12-30-2005 09:54 PM
Coolant drain JBrad Sprint Forum 1 05-08-2004 08:07 PM
