Suitable feed/connection - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-28-2009, 06:03 AM   #1 (permalink)
Favourite Bike: 2009 Tiger 1050cc
tigg-ted's Avatar
Other Motorcycle: Prev.T100,Sprint1050,955i
Thumbs up Suitable feed/connection
I've fitted a lubetronic oiler with the controller to my 2009 Tiger.
With a Scott Oiler dual feed located under the Swing arm.
I was able to fit the unit directly to the frame under the nearside seat cowl.
I've extended the filler pipe which is now accessable from the rear
Does anyone know of a suitable conveinient feed under the seat?
This needs to be ignition fed so only on when the ignition is on,
saving oil and battery, the unit itself has an inline fuse and minimal
current draw. I don't want to use a switch as I think I would forget to turn it on /off and that defeats the object of fitting the oiler to save wear and extend the chain life.
Any Ideas or previous experience with this type of setup please!
tigg-ted is offline
Old 07-28-2009, 08:14 AM   #2 (permalink)
No experience with the 2009 models, but I would think that the easiest thing to do would be to find an easy way to tie into the tail light. There should be a termination somewhere near the light that you can connect to without having to chop up your wiring harness. Just make sure you get the tail light, and not the brake light or it'll only work when you stop
zebulonsmith is offline
Passenger pegs---Daytona 675 suitable replacement? Sawdawg Speed Triple Forum 3 07-20-2009 04:57 AM
Givi X.01 Helmet - a suitable replacement SpiderTex Sprint Forum 14 05-19-2008 12:27 AM
Oh deer, is the rear brake resevior union suitable for the front karter257 Club Cafe' 2 05-06-2008 05:19 AM
Tank bad suitable for a chain? Reppyboyo Triumph SuperSports 1 04-09-2007 06:05 PM
Please wear suitable cold weather clothing when posting Archimedes Biker Hang-Out 30 01-25-2007 10:05 PM
