slow idle on start up - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-25-2009, 05:12 PM   #1 (permalink)
Favourite Bike: Triumph Tiger '05 BRG
Other Motorcycle: there are others?
Extra Motorcycle: on the hunt for one.....
Due to numerous reasons the Tiger had sat lonely for a month.
I have driven her 5 or 6 times in the last week, and each time after the engine has time to cool down, when I hit the starter and the bike fires up its idle speed is very very low for about 10 seconds....and sometimes stalls.....second start attempt it does fine and gets up to idle almost instantly. When warm it starts fine as well.
Acts almost like it needs "choked" but its an '05 955i --no choke--
Any suggestions?
The difference between genius and stupidity is genius has its limits
keystiger is offline
Old 07-26-2009, 10:41 AM   #2 (permalink)
Favourite Bike: 2005 Triumph Tiger 955i
The Kurgan's Avatar
Any suggestions?
If it means anything to you, my Tiger often requires two pushes of the starter button to fire-up when cold. Usually the first crank gets it running for a second or two (slow idle) then it "stalls", the second crank gets her running.
Its been like that since day 1 and I assume that to be the nature of my beast.
2005 Triumph Tiger 955i British Racing Green
Photos of my Tiger: CLICK HERE
Have a listen: CLICK HERE
R.A.T.# 1081696
The Kurgan is offline
Old 07-26-2009, 02:11 PM   #3 (permalink)
Put on a Happy face.
Any suggestions?
Both the 885i's i had were notorious for doing it,and when i spoke to others they had the same,when talking to a dealer and the factory,it was no names no pack drill syndrome!!!,but on the QT i was told the crank has a habit of moving and ignition pick up is slightly out of sinc,just turn the ignition off and start the motor again,my 955 does it from time to to time,i've known 3 or 4 attempts before my 885 would tick over ok.
winger is offline
Old 07-28-2009, 09:19 PM   #4 (permalink)
Favourite Bike: '06 Blue Tiger 955 Girlie
Blockhead's Avatar
Mine does it now and then, but only after sitting for a few days without riding. I'll try the switch off/back on method next time...
Mark
Blockhead is offline
Old 07-29-2009, 09:26 AM   #5 (permalink)
Favourite Bike: 2006 Tiger
Other Motorcycle: 1995 Speed Triple
I will second this. My 06 has done this since day 1
negruber is offline
Old 07-29-2009, 07:41 PM   #6 (permalink)
Favourite Bike: Bette 99 Tiger
Different model to yours, but I always let the injectors prime up - hot or cold before attempting to start. Might help???
PeteH is offline
Old 08-06-2009, 04:23 AM   #7 (permalink)
thats what mine did .Gave lamba sensor a nip up and never had a problem since.. CHEERS
clayrat.nz
rod.clayton@xtra.co.nz is offline
Old 08-26-2009, 06:39 AM   #8 (permalink)
Favourite Bike: 955i Tiger
Other Motorcycle: ex. Kwak Zephyr 750
Extra Motorcycle: 1050 Speed Triple, I wish
Low Idle
My 04 955i was sat for 3 weeks whilst I was away. Monday and yesterday it ran fine. Today when I started it the idle was very low. Once going it was fine on the motorway for 50 miles. When I came off the mway, it stalled at each junction once I released the throttle. It starts again each time but strange that its just started doing it. Any ideas ?
- The more I ride 'er, the more I luv 'er -
jimbo2807 is offline
Old 08-27-2009, 05:26 PM   #9 (permalink)
Talking
Hmmmm...After the issues yesterday morning, she was fine on the way home from work. And today she's been fine too. havent got a clue what went on then....
Maybe her time of the month..At least it only lasted for 1 morning :-)
Old 08-27-2009, 06:17 PM   #10 (permalink)
Re my posting,if you haven't had it before lucky you,just switch the bike off and start it again.
winger is offline
Starting / Warming Up. Slow tick over idle? riron2001 Twins Technical Talk 7 06-14-2007 04:51 AM
Engine speed slow to return to Idle Swoody Tiger Workshop (archive) 7 09-09-2006 12:54 PM
Slow idle Sluggo Twins Talk 3 03-22-2006 10:55 PM
Knocking sound at slow idle...smooth everywhere else Jim_in_Calgary Sprint Forum 4 06-17-2005 12:22 PM
Slow return to idle Tiger Workshop (archive) 20 05-06-2005 12:17 AM
