Fuel pump whine, normal on Girlie? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-18-2009, 02:29 AM   #1 (permalink)
Favourite Bike: Suzuki GS500E
Danny500's Avatar
When the bike was running last the fuel pump was EXTREMELY loud, it may be because it's directly under my seat and it only had a 1/4 tank of (8 year old) gas in it...
But is it normally so loud? I just installed the new fuel filter, fittings, and am about to drop the tank back onto the bike and fill her up but didn't know if I should run a little Lucas additive, or STP fuel injector cleaner in the gas as well.
My father suggested running a little bit of 2 stroke oil in with the gas just to have a little lubrication on parts that have been sitting out for a couple weeks.
Any suggestions? Or just a normal whine?
Danny500 is offline
Old 07-18-2009, 02:32 AM   #2 (permalink)
Put on a Happy face.
Mine has done it from the day i bought it 8 years ago.
winger is offline
Old 07-18-2009, 01:26 PM   #3 (permalink)
Danny500's Avatar
Ok perfect! I'll just throw a little Lucas/STP in the gas to clean out the internals of the fuel system and get all that bad gas out of there... If the whine remains, so be it... As long as it runs and rides, I have no issue as far as noise is concerned.
Thanks!
Danny500 is offline
Old 07-18-2009, 01:59 PM   #4 (permalink)
Favourite Bike: Bonne
Bookworm's Avatar
Other Motorcycle: Yamaha Warrior
wierd noises...if the air is cold....and best "sticky " wheels..any ideas?
I was quite relieved to read your posting, Danny.... as my bike ( 07 all black Bonne) makes the craziest noise if the air is cold. Originally, I thought that it was to do with the front brakes as it seemed to come from that direction- and that the whole bike was about to fall to bits. My husband assures me that it is something to do with pressures/ vacuums and fuel. I REMAIN UNCONVINCED! The thing is, the noise, which is like a high pitched scream - with remarkable "tremolo" feature- seems to "slow down" as I approach lights and slow/ apply brakes. It is so loud that any pedestrians nearby do a double take and stare at the engine of the bike. It stops as suddenly as it starts. It especially happens when the air temperature is low/ freezing.....OR IN THE DARK???? ( What' THAT all about??) So far, nothing has dropped off. Long may it continue...BUT, in the meantime, I'd still like to know , for certain, what it is. Anyone got any other ideas??? PS- in the UK, where is the best tyre place for a good deal and good despatch? Anyone got pearls of wisdom about tyres that remain steadfastly in touch with the road, especially in the wet... as it never seems to stop raining here and I am fed up with my current back wheel sliding out on wet roundabouts.
Bookworm is offline
Old 07-18-2009, 06:40 PM   #5 (permalink)
Favourite Bike: Tiger 1050
biketraveller's Avatar
Mine had the same problem...
Apparently this was a common gremlin with early girlies. Mine had it when I bought her new in 2002. It would begin as soon as the cold engine was started and would stop after a while when the engine heated up. It would also start once I went up above 2000 m (6100 ft), though I never found out if it was due to the chill in the mountains or the lower air pressure.
The fuel pump was replaced under warranty by the dealership and the next seven years and 200000 km it never appeared again.
The dealer told me at the time that he had replaced a number of pumps already, all with that "whining" problem.
biketraveller is offline
Old 07-18-2009, 09:15 PM   #6 (permalink)
KuzzinKenny's Avatar
Hey Bookworm !! I have used this lot and got a great deal and good service........
http://www.delti.com/cgi-bin/motorra...rt_id=&frame=1
sorry, have no idea about the other stuff !!
KK
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Old 07-19-2009, 06:26 PM   #7 (permalink)
Bookworm's Avatar
"mystery screams and sticky treads"
Dear KuzzinKenny( Tyre guru ) and Biketraveller...(200,000 KM????? HA! so COOL!) THANK you for yout timely replies and great bits of info. I have a master plan. By using this website I should be able to ensure that the normal, random mess that comes from my mouth, regarding all things motorbike-esque, will sound at least plausible!..so far , so good. I might just drop the "probably need the fuel pump replacing" comment, over breakfast. As for the tyre link, it will be soooo cool to be able to say, "Tyres, yeah, already on it. Scottish KuzzinKenny gave me a good link!" HA! CAN'T WAIT. Oh well, back to the housework! Thank you, both, again.
Bookworm is offline
Old 07-19-2009, 06:34 PM   #8 (permalink)
Bookworm's Avatar
To Bridgestone or not to Bridgestone?... that is the question!
Ok, KuzzinKenny.... Have checked out the link and, indeed, the prices are good... and I like the way you can match your bike up and they tell you what tyres you SHOULD have. My question is..."Bridgestone" tyres.... ARE THEY SOLID IN THE WET??? Does anyone have an alternative idea..... I suppose I could just go to "Ask Jeeves"... but I'm not sure he rides. ....
Bookworm is offline
Old 07-19-2009, 09:42 PM   #9 (permalink)
Cheerz for that, it made my day !! we`ve kindof hijacked this thread, sorry Danny500 !!
as yer bikes an 07 Bonnie isn`t it still under warrenty ?? i`d go see the dealer about the wierd noises and let them sort it out for free !! its good to have you down here in the Tigger Den but i think you`d be better checkin out the Twins forum and ask what they`re usin tyre wise !!
have fun !!
KK
ps your my 888th post !! i need to get out more
Old 07-19-2009, 09:55 PM   #10 (permalink)
Favourite Bike: 2005 Triumph Tiger 955i
The Kurgan's Avatar
My Tiger will make a similar noise after turning on the ignition in very cold temperatures, or when sitting for long periods of time.
See here on why:
http://www.triumphrat.net/sprint-for...tarting-3.html
2005 Triumph Tiger 955i British Racing Green
Photos of my Tiger: CLICK HERE
Have a listen: CLICK HERE
R.A.T.# 1081696
The Kurgan is offline
T140V Engine Whine - normal? Snakeoil Classic, Vintage & Veteran 3 05-21-2009 11:43 PM
Question about the fuel connectors attached to the fuel pump mounting plate zapata Speed Triple Forum 2 11-16-2008 11:11 PM
Help! Fuel Connector/Fuel Pump LeDude Speed Triple Forum 2 09-18-2006 10:58 PM
Fuel consumption normal? Fenris Sprint Forum 9 09-15-2006 04:51 AM
fuel pump and fuel injectors speedmerlau The Rocket Science Forum 5 11-01-2005 02:12 PM
