Tiger 1050 Ignition Bypass - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-05-2009, 08:58 PM   #1 (permalink)
Newbie
I have an 07' tiger 1050 and I would like to make a secondary method for starting the motorcycle other than the key. almost like a hidden push button start setup. I looked over the wiring diagram in the service manual thoroughly and found where I can make connections to bypass things like the kill switch and the ignition button.
The only thing left if the ignition switch. I assume that all the switch does is short all the wires together. I read some other forums about other motorcycles and bypassing the ignition requires a resistor or a diode across some of the connections as sort of a theft prevention method. Does anyone know how this can be done?
Also, do I have to interface with the wires at the ignition switch connector or can I interface with them under the seat. I would rather not cut into any of my wires, thats why I am trying to find a connector on the bike I can uncouple and plug my alternative switch into.
Thanks
burkferden is offline
Is the gearbox on the 1050 Tiger different from the 1050 Sprint? bareyb Tiger Chat 15 03-21-2011 06:34 PM
Tiger 1050 vs Sprint 1050 choclabguy Sprint Forum 10 01-11-2009 03:45 PM
Cat Bypass Pipe for Tiger 885i 1999 jamie_fixit Tiger Mods & Bolt-Ons (archive) 18 10-10-2007 12:16 AM
Ignition Advancer for Sprint 1050? coyote595 Sprint Forum 1 06-27-2007 11:43 AM
1050 Sprint vs. New 1050 Tiger bareyb Tiger Chat 32 05-21-2007 08:34 AM
