Oil top off and other issues - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearNew BonnevilleOntario TourismHonda PowersportsMotorcycle.com
Old 07-04-2009, 08:27 PM   #1 (permalink)
My '01 Tiger has been sitting for a year, and I want to get it back on the road.
Checked the oil and it looks quite dry. I'm afraid to start it without topping off. However, I can't find my owner's manual and have no idea where the oil would go. Any direction is appreciated. Also, should I be using synthetic oil?
Also, anything else I should be checking out after a year (besides the obvious fluids, tire pressure, etc.)?
tigersd is offline
Old 07-04-2009, 08:32 PM   #2 (permalink)
Favourite Bike: Bette 99 Tiger
Probably start with the battery
PeteH is offline
Old 07-04-2009, 08:34 PM   #3 (permalink)
It is already on the tender. That part I figured out. ;-) Thx.
tigersd is offline
Old 07-04-2009, 08:55 PM   #4 (permalink)
KuzzinKenny's Avatar
To check the oil, bike should be upright on its wheels ( not on sidestand ) dipstick/filler is on the right side just above footbrake !! remove dipstick, clean, replace fully, remove dipstick and read level, full is to the upper end of this mark XXX, if needing toped up it should be synthetic oil. if the bike has a centre stand it might be worth while putting it on it, put bike in top gear and turning the engine over a few times just to make sure nothings stuck !! the petrol might be sour so might need replacing.
hope this helps !!
KK
ps Welcome to the Tigger forum !!
04 Triumph Tiger in Lucifer Orange !! Purrrrrrfect !!
KuzzinKenny is offline
Old 07-04-2009, 08:57 PM   #5 (permalink)
I dont have a 955 so Im guesing, you dont have a window for oil level check and have a dip stick instead?? Oil probably goes down the dipstick hole? best use fully synthetic too, Im using Castrol, but do a search on here to find what others use.
Pete
Beat me by a minute KK
PeteH is offline
Old 07-04-2009, 08:58 PM   #6 (permalink)
Found the manual and looks like the oil goes in the same place as the dipstick, so that mystery is solved. Also, will go pick up some 4T on Monday.
But any suggestions on what I should check out before getting back on the road would be appreciated.
tigersd is offline
Old 07-04-2009, 09:06 PM   #7 (permalink)
[QUOTE=tigersd;1310164But any suggestions on what I should check out before getting back on the road would be appreciated.[/QUOTE]
Check all bouncy bits- bouncing ok
Check stoppers- not siezed ie pads not sticking
Check all lights ok
Best also to check you, take it easy(if you`ve been off the road with the bike)
Ride safe and enjoy
PeteH is offline
Old 07-04-2009, 09:23 PM   #8 (permalink)
thats cos i missed the important bits...................
Quote=PeteH - Check stoppers- not siezed ie pads not sticking !!!!!!!!!!!!!!!!!!!
Doh !!
KK
Old 07-04-2009, 09:48 PM   #9 (permalink)
Check all lights ok
Ride safe and enjoy
Got it. Thanks. And will do.
tigersd is offline
Old 07-05-2009, 04:29 PM   #10 (permalink)
How do you know if the gas is sour?
tigersd is offline
Known issues Spyda Sprint Forum 14 02-20-2009 06:49 PM
TT 600 Run Issues NSTriumph Triumph SuperSports 3 04-08-2008 04:13 PM
A Few Issues DrewDesign007 Twins Technical Talk 20 02-05-2008 09:25 AM
Known Issues DrewDesign007 Twins Technical Talk 12 08-08-2007 08:08 AM
01' S3 Issues? mnrider Speed Triple Forum 8 12-05-2006 11:32 PM
