Trident-Exhausts.comBikeBanditAdvanstarMotorcycleShows
Tiger Mods & Bolt-Ons What's on your Tiger?
Old 03-21-2005   #1 (permalink)
ipg
Where did you guys who have fitted GPS and communications find was the best way to take the power; direct from the battery with in-line fuse or off existing wiring somewhere??
IPG
Keep it rubber side down!
MyPhoto Album
ipg is offline   Reply With Quote
Old 03-21-2005   #2 (permalink)
There are several fuse blocks available. I found a completely enclosed box I just can't remember where I got it.
2ndSpace is offline   Reply With Quote
Old 03-21-2005   #3 (permalink)
robbie's Avatar
have a look in the album
i used the heated grips connector
stuck in some switches and inline fuses. run everything of them.
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
My Photos
robbie is offline   Reply With Quote
Old 03-22-2005   #4 (permalink)
Favorite Bike: Tiger1050
chrisn's Avatar
Other Motorcycle: Rocket3
I've always found it's an easy task to route a lead direct from the battery with an inline "blade" fuse housed in the battery box. This way you can easily pull the fuse when supply is not required for extended periods, as some accessories still put a small drain on the power supply even when not in use. It's also easier than opening up the cockpit for connections.
Chris
chrisn is offline   Reply With Quote
Old 03-22-2005   #5 (permalink)
BigStripey's Avatar
I have got a small fused junction box behind the fairing that has 4 outlets from it, which i run my GPS, Phone Charger & Digitool gear indicator. I ran the supply lead for this junction box from a switched live on the fuse box. That way i cannot leave anything on when i turn off the ignition.
Big Stripey
BigStripey is offline   Reply With Quote
Old 03-22-2005   #6 (permalink)
ipg
Thanks guys for all the info!
BigStripey
Can you give me more details on how you did this as it sounds like a good way of powering multiple items. Where do you make the power connection in the fuse box and where did you buy your fused junction box. I'll tackle most jobs but I'm a bit nervous on mucking about with the electrics I must admit. Thanks.
IPG
MyPhoto Album
Old 03-22-2005   #7 (permalink)
I can hear you now Jim. Oh no, not another Jock with a phobia for electrics :-D
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Old 03-23-2005   #8 (permalink)
BigStripey's Avatar
IPG,
I got the plastic box from Maplin Electronics, they do loads of little sealed electrical boxes. I then drilled a total of five holes in the sides of the box (which is a bit bigger than a box of matches?) I then put a wiring grommet in each hole to make it pretty weatheproof.
The switched live wire comes in from the fusebox through the grommet. and inside i have put a blade fuse holder (5 amp) in line. The live then goes into a simple connector block, which i then connect my devices to(each one coming in through a different grommet). I also have a good earth (ground) wire running into the box as well, to save running earth wires all over the front of the bike.
It is a simple little job, but it does mean that you can loom all the wires up properly and make a neat job of it.
I need to check the fuse box to say what fuse number it was that i took the switched live from?.....i'll update that tomorrow. And next time i've got the front end off, i'll take a photo and post it up.
Hope this helps...
Big Stripey
Old 03-23-2005   #9 (permalink)
BigStripey's Avatar
IPG,
Hope this helps...
Big Stripey
Old 03-31-2005   #10 (permalink)
Favorite Bike: Tiger 1050
Other Motorcycle: Fazer 600
Being in the process of convincing myself to replace the cheapo comms unit with an Autocom, I'm looking at electrics myself - just having a look in the handbook, and can't see any fuses for heated grips (given bike being a 2000)? Does this exist?
According to my handbook, fuse 10 is the accessories fuse, anyone got any idea what this powers? Is it only the power outlet under the tank? Is this switched?
Jim - which switched live did you take power off for your extra power box?
Any help much appreciated, same as IPG I've got a bit of respect for the electrics, don't want to mess around too much, although I like things being tidy.
Stupid question last - I assume earth is negative (?) but where do you guys take it from? On a car you can sort of take it off any bodywork, do you have to take it off the battery on the bike?
TorqueyT
TorqueyT is offline   Reply With Quote
GPS power lead (again)!! Timber Wolf Sprint Forum 2 08-05-2007 12:29 PM
GPS Power cables - HELP! Saffer Twins Technical Talk 4 05-21-2007 02:52 PM
Power for a GPS 2trumpets Hinckley Classic Triples 11 12-30-2006 04:54 PM
GPS power supply witness Speed Triple Forum 4 08-08-2006 04:44 AM
GPs Power Connection ManicMarvin Sprint Forum 8 07-01-2006 06:43 AM
