Originally Posted by devil-stick
Sorry to be a bore and ask a most likely stupid question but...
Just bought a 54 Tiger and it has an aux power point to the left (BMW style) but has a normal car sized one on the dash...
Am i right in assuming that they only come with one aux power outlet as standard? The one on the dash doesn't appear to work with anything i've tried in it and i dont have the correct adaptor to try the smaller BMW style one.
Is there any way to test wether there is any power flowing through it and what could be the problem if there isn't?
I know it's a big long ramble but any help is much appreciated!
D-S
Big long ramble? Hardly a stutter compaired to some of the drivel typed in here
. Wecome aboard by the way, keep asking your questions, you will get answers from the masses.
You are correct the bike only came with the one on the left side as standard. I suggest that you start checking the other one by tracing the wiring back from the socket to where the previous owner plumbed it in, check all of the connections as you go & chjeck for fuses, relays etc. I would do this as a matter of course for added electrics as you don't know the competence of the installer, if you are unsure about working with wiring find a buddy or tame spark who is & play on their good nature.
D
