Motorcycle.com
Tiger Mods & Bolt-Ons What's on your Tiger?
Old 02-27-2008   #1 (permalink)
Newbie
Higher gearing / sprocket change
Any advice welcomed for sprocket change on '06 955 Tiger to give more relaxed cruising revs, without sacrificing too much pull low down. Thanks.
tiger956 is offline   Reply With Quote
Old 02-27-2008   #2 (permalink)
The most popular mod is to up the gearbox sprocket to 19 teeth. I've done this on both my 885 and 955 Tigers.This drops the revs at motorway speeds by about 500 revs
MrGromit is offline   Reply With Quote
Old 02-27-2008   #3 (permalink)
sheepshagger's Avatar
Yup, up the front sprocket to a 19 tooth - easy mod to do and lowers the revs at cruising speed but has virtually no difference to acceleration lower down the rev range. Along with stiffer front springs it's one of the best mods that I've done to my '05.
Good luck
sheepshagger
tea one sugar thanks
sheepshagger is offline   Reply With Quote
Old 02-27-2008   #4 (permalink)
Sprocket change
The first mod I made to my '05 955 was to install a 19 tooth gearbox sprocket. No change in the acceleration and reduced cruising RPM much better. Took about one hour to make the change. It helps that I have the optional center stand.
britone is offline   Reply With Quote
Old 02-28-2008   #5 (permalink)
blacktiger's Avatar
+1 on that. The engine is tractable enough to pull that even off road.
H
'02 Tiger955i in black.
Old 02-29-2008   #6 (permalink)
clive955's Avatar
Seems i went the other way round than most and fitted a 42 rear, Same results though, 80 mph and just over 5000 rpm and still and quick getaway
Green is Mean
clive955 is offline   Reply With Quote
Old 02-29-2008   #7 (permalink)
blacktiger's Avatar
Thing is Clive. With replacing the front, you don't have to alter the length of your chain. Indeed, I've fitted a 17, 18 and 19 all with the same chain. There's enough adjustment in the eccentrics to cope.
Also, a bigger sprocket gives the chain an easier time because it doesn't have to "bend" so much to go round the sprocket.
Yet another plus is that the bigger sprocket helps to keep the chain away from the plastic guides on the swing arm.
H
Old 03-03-2008   #8 (permalink)
Favorite Bike: Triumph Thruxton 900
Other Motorcycle: Harley Road King Custom
Extra Motorcycle: Unity Bobber being built
Same on 1050?
Guys, is this mod the same (relevant) on the 1050? I like the bottom end pull, but would like to drop my highway rpm some.
Chappy
Biker Chaplain
www.bikerchaplain.com
Harleytoo is offline   Reply With Quote
Old 03-03-2008   #9 (permalink)
clive955's Avatar
Blacktiger,
Hear what your saying and understand why you would change the front if thats all you were doing, I was at the time though replacing both sprockets and the chain as the old front sprocket was fairly well hooked and the chain had seen better days !!!
Green is Mean
Old 03-05-2008   #10 (permalink)
blacktiger's Avatar
I think, but not sure, that the 1050 tiger starts off with a 19T. Don't know if a 20T is available.
H
Looking to change gearing? Front or rear? fernman Speed Triple Forum 13 09-27-2006 07:16 PM
gearing and tyre change Qual Speed Triple Forum 6 03-14-2006 10:21 PM
Sppedometer error with gearing change? DanPtWash Speed Triple Forum 8 02-13-2006 12:52 PM
Change S3 gearing; any recommendations? carbster09 Speed Triple Forum 8 01-05-2005 11:39 PM
Front sprocket gearing change Netmaker Trophy 5 05-29-2004 07:21 AM
