Motorcycle.com
Tiger Mods & Bolt-Ons What's on your Tiger?
Old 02-22-2008   #1 (permalink)
Favorite Bike: Tiger 05
Silverstripes's Avatar
Red face LED Indicators
Yep gone and converted to LED's.
I did not change the outer shells. I removed the plastic chrome reflector and made a plastic backplate the same shape.
I then drilled 5mm hole to the patern of my choice. On the front I have 25 Yellow LED's and the Rear with 20 Yellow and 5 Red, in a line in the center. The 5 Red's are wired to the Brake lights so you get the standard brakelight plus both indicators red.
The LED's were 6000 MCD and cost 7 GDP (good old flea bay). I had to replace the flasher with an electronic one again 8 GDP.
Result is that with the standard lens replaced the Red is just right and the yellow more of a spead, easier to see and much brighter than standard.
Next project is the stop and tail conversion, again to LED's
Just cant leave it standard !!!!
Silverstripes is offline   Reply With Quote
Old 02-23-2008   #2 (permalink)
snakebasket's Avatar
Other Motorcycle: Laverda sf
Extra Motorcycle: Triton
Hi, sounds great, any pictures and a chance of links to the ebay suppliers?
snakebasket is offline   Reply With Quote
Old 02-23-2008   #3 (permalink)
Talking
Yes I will get some pictures up at some stage.
Also when I do the tail light I will do a stage by stage photo run.
Bottom line it depends on how many LED's you want to install and then I worked out an even patern.
I did put the LED's in clusters of 5 with a 27 OHm restitor rather than individual resistors. this cuts down on the space needed and if ther is a failure it would only be one group of 5.\
As I said pics to follow.
Old 03-02-2008   #4 (permalink)
Talking
For pictures of the LED indicator conversion clicky here. http://silver-stripes.blogspot.com/
Have a go.
Any questions PM me.
Old 03-06-2008   #5 (permalink)
Favorite Bike: Sprint ST
Nice!
Nice job on the indicators. Looks like that was was a fun little project.
Did you consider having the LED's work as running lights?
Cheers!
Mike
PS...keep up the good work.
Future Ride...(on the fence)
05+ Sprint ST ABS || 07+ Tiger ABS
__________________________________________________ _______
Past Rides...
'03 Suzuki SV1000N = RIP, '98 Yamaha TRX850, '75 Yamaha RD350
okimic is offline   Reply With Quote
Old 03-07-2008   #6 (permalink)
Yes I did consider running a row of whites on the front as I did Reds on the back (For Brake warning). This row of whites in both sides would be running lights. However I chose not to do this as the lens are standard and there was a risk of the running light showing orange. his may confuse a car driver waiting to pull out if they could only see one indicator.
I chose therefore not to do this and stay with 25 nice and bright yellows in the front.
I do have the twin headlight conversion and I also have a set of auxiliary lights running with the headlights when on main beam or the overtake flash switch. I will put this mod on my site next.
LED indicators - Help! Navy Boy Daytona Deliberations 12 03-25-2008 09:58 PM
LED Indicators blackfly Hinckley Classic Triples 4 06-13-2007 02:31 PM
LED Indicators Silverstripes Tiger Mods & Bolt-Ons 0 04-01-2007 01:05 PM
LED Indicators robnobrakes Speed Triple Forum 7 09-19-2005 11:24 PM
LED indicators Modifications & Workshop Talk 11 12-07-2004 09:20 AM
