Motorcycle.com
Tiger Mods & Bolt-Ons What's on your Tiger?
Old 02-02-2008   #1 (permalink)
RT
Favorite Bike: 06 Tang & Opal T-100
RT's Avatar
Other Motorcycle: 06 Tiger Caspian Blue
Extra Motorcycle: 07 America Black & Chrome
TOR installed
Picked up the new TOR exhaust today and got it installed. Moving the heat shield took the most time. Went for a short run and am liking the new sound. Tiger goes grrrrrrrrr now.
Confused and Prone to Wander
RT is offline   Reply With Quote
Old 02-02-2008   #2 (permalink)
Just out of curiousity what all did you have to remove to install the pipe? It looks fairly straightforward just looking at the bike.
Joe S. is offline   Reply With Quote
Old 02-02-2008   #3 (permalink)
RT
RT's Avatar
Just the lower bracket on the pipe and the bolt that holds the bracket on the back of the silencer. All slides off then.
Drilled out the rivits on the heat shield. Than ended up using rivits to reattach to silencer. That took awhile to do. Couldn't get the rivits supplied by Triumph to pop. Ended up having to cut the gun off one and grinding the head down. I know others say they have used screws but thought might be to easy for them to vibrate loose.
Old 02-03-2008   #4 (permalink)
Favorite Bike: Triumph Tiger
MAX21's Avatar
Straight through is best a tiger should ROAR!!!!!!
MAX21 is offline   Reply With Quote
Old 02-18-2008   #5 (permalink)
Other Motorcycle: Ducati 749
If a rattly heat shield annoys then it will be worth buying a pop rivet gun and a stock of rivets. I find that the aluminum rivets stretch and loosen off, causing the heat shield to rattle. If I was fussy I'd re-rivet it every year.
greenman is offline   Reply With Quote
Old 02-18-2008   #6 (permalink)
Best to use self tappers into those spiral spring retainer thingies (whatever the proper name is) that clip nicely over the braket holes.
Pickaxe is offline   Reply With Quote
Old 02-21-2008   #7 (permalink)
Favorite Bike: '06 Blue Tiger
Blockhead's Avatar
I just got my tor installed with tune today. I am VERY pleased with the result! Runs much smoother and seems to have a little more pep. The sound is very nice without being offensively loud. Nice growl. I wonder how the TOR compares to a Blue Flame as far as sound?
The dealer had to charge up my battery since they said you have to have the lights on to load the tune and it had drained the battery somewhat.
Does that sound "normal'?
Bloody rain & cold swung back in, so I'm going to wait until tomorrow to run her some more to make sure the battery is strong. Not to mention to listen to her new vocal chords too!
Block
Blockhead is offline   Reply With Quote
Old 02-21-2008   #8 (permalink)
RT
RT's Avatar
Block
Yep it's normal. The lights will suck a battery quick. Always have mine on battery tender so I have a full charge before heading out and about.
Love my TOR. Really nice sound but not to bad when you get her up to speed. Wife hasn't ridden with me since I did the install, will see what she thinks when she is on the bike.
Old 02-22-2008   #9 (permalink)
Favorite Bike: 06 Tiger
It is normal to turn on the ignition as the ecu has to be powered up to load the tune. It is also normal for the dealer to pull out the headlight fuse so your lights don't needlessly drain the battery.
TJoe is online now   Reply With Quote
Roadtest observations: '07 TOR tune with NO TOR... TheNomad Sprint Forum 12 08-27-2007 06:50 PM
TOR installed yesterday steveno Sprint Forum 27 08-22-2007 05:29 AM
Pictures of the TOR installed or before install please? TheNomad Sprint Forum 16 06-30-2007 01:02 PM
TOR carbon Can and TOR Tune fitted Today Thefallenone Sprint Forum 3 12-29-2006 10:55 PM
'06 Black back from 500 mi svc-TOR pipes installed HowieL Twins Technical Talk 4 06-23-2006 08:33 PM
