Tiger Mods & Bolt-Ons What's on your Tiger?
Old 01-31-2008   #11 (permalink)
Robbie, where did you get that square section tubing from.? Thanks
MrGromit is online now   Reply With Quote
Old 01-31-2008   #12 (permalink)
robbie's Avatar
we had some in our stores here at work so I managed to find some off cuts in the waste bin
all you are trying to do is space the light out a bit.
as you can see 50mm is a little bit on the big side but we dont carry 40mm box
you could use almost anthing to space the light but the light is mounted on rubber spools so long bolts and washers will add vibration that the bulbs may find rough, but you could make long nuts to do the job.
Max
if you need to have a solid look then turn the spacer 90degrees and work from the top, that way less weight
also if i was doing the job again I would stagger the holes to raise the light a few mm just to give more clearance,
Robbie and 'Mohan' the original Silver Tiger
TIGER 955i 2003
My Photos
robbie is offline   Reply With Quote
Old 02-04-2008   #13 (permalink)
Just noticed on TriumphTiger online that they now have number plate bolts that have lights built in to overcome the problem with the Scottoiler tank behind the number plate.If I was not such an electrical numpty I would fit them.
Scottoiler Paddy Tiger Mods & Bolt-Ons 8 10-15-2007 03:22 PM
Scottoiler TripleTreat Sprint Forum 2 11-10-2006 02:32 AM
Scottoiler..... casperghst42 Sprint Forum 2 05-23-2006 09:30 AM
Scottoiler llewpants Tiger Mods & Bolt-Ons 21 02-22-2006 02:01 AM
Scottoiler for 05 ST STman Sprint Forum 8 07-28-2005 03:57 PM
