Tiger Mods & Bolt-Ons What's on your Tiger?
Old 01-02-2008   #1 (permalink)
Favorite Bike: 07 Tiger
Other Motorcycle: Several over the years
19T front sprocket on a 1050
Those of you who swapped out to a 19 tooth front on the Tiger 1050, what effect did it have on the bike? Better mileage? Less vibration at touring speeds? Other? In retrospect, did the swap meet your expectations?
I'll be riding to Tennessee and back this June (2500 miles) and was wondering if that mod would be worth it.
TIA, Pete
Tiger_1050_VT is offline   Reply With Quote
Old 01-02-2008   #2 (permalink)
Favorite Bike: '03 T-100 & '07Tiger1050
IMHO, you would be doing your engine a favor by leaving the stock sprocket on the bike. I have ridden my 790 bonnie all day between 5000 and 5500 rpm and gotten 50+ mpg. I ride the Tiger the same way and I get 50+ mpg on it...I just have not ridden it as far due to a bad weather year. The Tiger is smoother, has loads of torque...I just can't understand the desire to try to make it run at low rpm like a V-Twin; but then, I can't understand that with the bonney twins either.
Larry
Old 01-03-2008   #3 (permalink)
RedBird -- That's why I asked the question. My cat gets 50-56mpg depending on how I ride, and it seems like it would purr all day on the highway. I don't notice any vibration that would be annoying over the long haul, but my longest ride so far on this bike was only 400 miles. Just trying to understand the rationale, and if it made sense in some way I hadn't thought of I might go there.
Thanks for your input.
Old 01-15-2008   #4 (permalink)
HiVel's Avatar
I tried several different gear ratios on both my T100 and my Speed Triple-went back to stock on both bikes for all around use that cannot be beat IMHO.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
19t counter sprocket Boriqua Twins Technical Talk 24 09-09-2007 11:17 PM
CS sprocket 18t vs 19t Geoff Twins Technical Talk 4 08-27-2007 12:46 PM
19T sprocket stu Twins Technical Talk 17 06-20-2007 08:04 AM
1050 front sprocket nut, which side in? Martin_R Speed Triple Forum 2 03-05-2007 03:14 PM
19T sprocket on Thrux Boozer Twins Talk 14 05-19-2006 09:05 PM
