Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Tiger Mods & Bolt-Ons What's on your Tiger?
Old 09-17-2007   #1 (permalink)
Handlebars 955
After100+ miles I start to get an aching back (nothing wrong with the bike, it's me age you know) I also have really long arms. I would like to fit lower handlebars to make me lean forward more which will stop me from riding with a vertical back and also load up the front wheel a bit more.
has anyone else fitted lower bars to a Tiger 955?
Any pictures?
Would the bars from a 1050 tiger be of benefit?
what diameter are the Tiger bars, I presume there is nothing peculier in size and fitting.
Tigerbob is offline   Reply With Quote
Old 09-17-2007   #2 (permalink)
marauder2's Avatar
you could always fit the bars of a 885 from 1999,they are lower and pull back a bit more,i changed mine for 955 bars and i get a bad lower back now after 200+ miles,the 885 ones are £60.00 from the dealers c/w built in crossbar.
marauder2 is offline   Reply With Quote
Old 09-17-2007   #3 (permalink)
Wink 885 Bars
thanks for the info, bars off an 885 is something I hadn't considered, I will certainly look into it.
Old 09-17-2007   #4 (permalink)
dword's Avatar
Lower?
one mans trash is another mans treasure..
I am in the process of ordering taller bars with a little bit of a backward angle.. ]
my wrist hurt from leaning on them.. and I'm 6ft tall on an 06 Tiger
dword is offline   Reply With Quote
Old 09-18-2007   #5 (permalink)
Favorite Bike: 05 tiger
brgtiger's Avatar
Other Motorcycle: 06 scrambler
my friend put lower bars on his 05 tiger. the bar is 7/8". my first stop would be flanders bars and check all their bends. decide what height and pull back you want then look at their extensive list of bends and see if they have what you want. you can also look at the pro tapers and maybe drz400 suzuki bars. they are simular in pull back but they are lower...have fun.
Joe
05 tiger
06 scrambler
brgtiger is offline   Reply With Quote
Old 09-18-2007   #6 (permalink)
MX bars
I had a bad wreck in December that bent the bars. Since OEM bars were $90, I opted for $60 aluminum MX bars, can't remember the brand now, not Renthals, but those fit too. There are different shapes available, go to a local shop and pick. You can't mount those shiney bar-ends. There was some trouble fitting the heated grip wires, but it's done and works. Supposedly the aluminums absorb vibrations, etc, but I just did it because they were cheaper..
jaak is offline   Reply With Quote
Old 09-23-2007   #7 (permalink)
Other Motorcycle: Ducati 749
Lower Bars
I fitted some Renthals, pictures on the forum showing the difference. There're quite a bit lower and do foul the Vario screen but are ok on a standard screen.
I much prefer them, and I don't have long arms.
Link to photo:
http://www.triumphrat.net/photogalle...6/aax.jpg.html
greenman is offline   Reply With Quote
Old 09-23-2007   #8 (permalink)
Renthals
Hi Greenman, thanks for the response, the bars in you pic is just what I am looking for.
Do you have a Renthal part number/style?
Did you have any problems fitting the bars? Electric grips etc
Did you drill holes for the switch locating pegs in the bars or did you file the pegs off?
Old 09-29-2007   #9 (permalink)
blacktiger's Avatar
Be careful when fitting MX bars.
When I needed to replace the bars on a R100GS following an off-road off, I made the mistake of just going to my local MX dealer and buying the first bars I could find and quickly found that they crippled my wrists. The bend was too shallow and cocked my wrists inwards unnaturally. Probably great for jumping table tops with your elbows high but not for long distance touring.
I eventually found some Renthals that matched the original bend on the BMW bars but were MX type low (I used bar risers to get them a similar height to original).
They are :- "PRE-88 PATTERN" Pt.# 707-01-SI-01.
As for heated grips. The BM grips went on OK and I drilled holes between the clamps to fit the cables down the centre of them OK. I did, however, find that the grips were less effective with the alloy bars and I think that was because the alloy conducted more heat away along the bars instead of into my hands. Maybe???
H
'02 Tiger955i in black.
Old 09-30-2007   #10 (permalink)
Bars
I can't find the Renthal part number but I remember they were for a Yamaha motocrosser. I drilled holes for the switchgear locating pegs as I don't think the switches grip the bars too well.
I bought the bars from M&P or somewhere like that; the website had a comprehensive list of handlebar dimensions. They are approx 730mm wide, have an 80mm upsweep and 65mm backsweep.
You won't be able to fit the bar ends as these (and all aluminium bars) have a smaller inside diameter.
Happy tinkering.
955 Daytona and 955 Tiger Trunkie Tiger Chat 6 03-20-2007 12:38 PM
Handlebars Anne Twins Technical Talk 5 10-09-2006 09:30 AM
Handlebars: 05/06 vs. 02-04 Captain_Rat Speed Triple Forum 0 04-15-2006 09:30 AM
handlebars tnsen Classic, Vintage & Veteran 0 08-09-2005 11:47 AM
955 daytona 955 speed triple blkse04 Daytona Deliberations 12 04-20-2005 04:38 PM
