No space behind or above the license plate (I have the Kisan vectralight LED license plate frame). I think I am going to put the resevoir behind the side panel. It is only a couple of screws to remove, but it may be the last place left unless I zip-tie it to the Givi mounts (the least elegant solution, but more functional).
I saw someone who fashioned another tube into the resevoir (mounted behind the side panel) so that it could be filled from under the seat, rather than having to remove the screws and pull the panel...
Thanks,
bluz
"Until lions have their own historians, tales of the hunt will always glorify the hunter"
– African Proverb
