Motorcycle.com
Tiger Mods & Bolt-Ons What's on your Tiger?
Old 05-29-2007   #1 (permalink)
Favorite Bike: 2004 Tiger (Black)
I found that my tiger needed to have the preload set at 4-4.5 to have the front end not feel light. I weigh 230 or so with gear. This preload made the bike just a little taller than I wanted; I couldn't quite flat-foot it. So, this weekend I raised the front fork tubes in the triple-clamps around 15mm. This let me reduce the rear preload to 3. The front end feels very well planted and the handling seems a little quicker.
has anyone else done this?
PizzaMan
2004 Triumph Tiger (Black)
pizzaman383 is offline   Reply With Quote
Old 05-30-2007   #2 (permalink)
Hi Pizzaman383, I have dropped my forks through by about 10mm and have the preload set on about 4 on the rear, I weigh about 120kilo and the bike handles much better, the front end does not feel as spongy as it did before and at 6' 3" I can just get both feet down flat footed.
If it's not green, it ain't mean!
Jacko34 is offline   Reply With Quote
Old 05-31-2007   #3 (permalink)
Other Motorcycle: Ducati 749
There's plenty of threads here on lowering the front by up to 24mm. Mine's at 22mm right now and when I can find the time I'll probably change it back to 19mm as it seems a bit too ready to drop into corners. OK for a sports 600 but not what I want from this great big green thing.
greenman is offline   Reply With Quote
Old 05-31-2007   #4 (permalink)
Old 06-01-2007   #5 (permalink)
BigStripey's Avatar
Up to the '05 models (which had the steeper rake angle) raising the fork legs really makes the difference. I have tried everything from 10mm up to 22mm.
The best setting i have found is 19mm, it lets the bike turn in really easily but not 'fall in' like it does at 22mm.
Big Stripey
BigStripey is offline   Reply With Quote
Old 06-01-2007   #6 (permalink)
I'm measuring the distance I raised the forks between the top of the triple-clamp to the line where the cap and the fork tube meet. Is that the right way to measure or do you measure from the triple-clamp to the top of the fork nut?
PizzaMan
Old 06-05-2007   #7 (permalink)
pizzaman, you are correct - the measurement is usually taken from the top of the yolk to the top of the stanchion
MrChrome is offline   Reply With Quote
Old 06-06-2007   #8 (permalink)
dropped mine by 10mm and what a difference. I wouldn't go as far to say that its sports bike flickable but it is a lot more manoeuvrable and balanced. Seems to dive less as noted above and frankly, I'm well chuffed.
Someone well adjusted to me a favour ? FifeTiger Tiger Chat 3 08-28-2007 03:32 AM
How many here have adjusted their own valves? Triple_Rider Speed Triple Forum 27 01-23-2007 10:45 PM
Tiger's slipping to second place in my heart Jamo Tiger Chat 12 12-19-2006 10:36 AM
MInimum tools to change the Tiger's tire's/tyre's TiggerTwo Tiger Workshop 5 06-28-2006 12:38 AM
Cornering Techniques/Tiger's Natural Environment FifeTiger Tiger Chat 16 04-18-2006 04:18 AM
