Motorcycle.com
Tiger Mods & Bolt-Ons What's on your Tiger?
Old 04-17-2007   #1 (permalink)
OrangeTiger
I am new to the Tiger and Triumph world, but have been riding in Canada for a number of years. As such, I would like to install some heated grips and wire-in a heated vest and possibly pants, as I'm an early morning rider and even in the summer, can still be a bit nippy in the mountains.
Does anyone know what is the max. loading I can put on the electrical system for external gear for my 2005 TIGER? I've burned a stator out in my younger years which created a less than ideal situation for where I was at the time.
Thanks
[ This message was edited by: OrangeTiger on 2007-04-17 10:24 ]
Old 04-17-2007   #2 (permalink)
Favorite Bike: 01 Tiger
Other Motorcycle: 02 Sprint RS
Extra Motorcycle: another 01 Tiger
The power outlet (accessory circuit) is fused at 10 AMPS. That is also the circuit that runs the factory heated grips. I think the only other things on that circuit is the clock and the backup power for the trip mileage
nortoncharlie is offline   Reply With Quote
Old 04-17-2007   #3 (permalink)
kiquekk
If you are thinking of how many Watts are you able to drain to power up all that stuff, it is 12V*10A=120W
The heated grips drain 20W (I'm not sure)...the rest are for your own use
Old 04-18-2007   #4 (permalink)
my Klan heated vest takes 3 amps.
krull is offline   Reply With Quote
Old 04-22-2007   #5 (permalink)
Orange Tiger
Where are you located? Sounds like Alberta! I mlive in Cochrane and ride a 06 Silver Tiger.
jpattigr is offline   Reply With Quote
Old 04-26-2007   #6 (permalink)
OrangeTiger
First, thanks for advice, and yes, I was looking for the available amperage.
Calgary is home, and I would have bought an '06 Tiger except mine HAD to be orange, so I had one shipped from Montreal last spring (one of the last new Orange ones left!!)
Old 05-15-2007   #7 (permalink)
:yayyy: Canadian tiggers sweet. I am frm Saskatoon, Black 2002
katblack is offline   Reply With Quote
Old 05-21-2007   #8 (permalink)
Favorite Bike: Sprint ST
Also,
Most of the heated gear that I've looked at that interlocks together comes with it's own plug. According to the owners manual the aux. plug can take a max of 10a load. The actual draw of Amperage is going to vary from manufacturer to manufacturer. I've seen heated vests that take up to 7 amps to run. A direct lead to the battery will usually do the trick and avoid damaging your factory wiring too. If you only plan on using a heated jacket and not full gear then the factory plug should be fine. If you do socks, pants, shirt, and gloves then add in a new plug.
rew7602 is offline   Reply With Quote
slow loading sweatmachine Happenings and Discussions 4 02-07-2008 12:20 AM
Loading Motorcycle Into PickUp dblhelx Speed Triple Forum 27 12-03-2007 05:19 PM
loading tune johnO Sprint Forum 2 06-22-2007 05:48 AM
Just dumped my bike of a loading ramp ,Need parts! srv335 Daytona Deliberations 10 06-07-2006 12:57 AM
Tiger Loading JRO Tiger Chat 2 11-23-2005 11:06 AM
