Blimey!!!,number of answers come down to'Can you afford it',if the answer yes,you'll find the shock is the same from 99-04 i'm not sure after that.
Most of the different makes have remote preload ajusters but the Ohlins is standard were the others are an extra,but their cheaper in the first place
I've been the same route with the shock,rideing from Lisbon to Salamanca,get of the bike wife says to me is the rear shock OK?? i'm thinking if she's notice it!!!! got home put an ohlins on.
Have any exsperience with aftermarket shocks??,if not deal with someone you can talk,to make sure you get the correct spring,if you ride both one up and two up you will definetly need a preload ajuster,just make life easier(and quicker).
As for which make,Hagon,Ohlin,Whitepower,Wilbers, are the main ones,how much you want to pay,quality,and who's close to were you live if you have a problem,are the main things.
Is it worth it??,it's only when you put an aftermarket shock on you realise just how bad the standard one is.
