Take off the front seat, and then lay it on the tank (they recommend polishing the tank first btw)
The two back straps go round the frame sides behind the tank and do up to themselves. This is a bit fiddly, but is possible - I think I undid the side panels which helps a lot.
The centre long front strap goes round the headstock, left to right, under the top plate and does up to its corresponding buckle.
The side straps have clips to secure them to the side panels. Mine kept coming off and I eventually used the clips to secure them round my engine bars instead.
The front corners have small pockets to go over the tank corners.
Dont do the straps up too tight , but allow the cover some days to seat itself. After that it fits better, then you can snug the straps up.
Dont do the back ones too tight cos it can damage the front corner pockets..
Hope thats the right cover described :???:
Good luck!
Jim
